![]() | Home > In Car Electronics > In Car Head unit replacement issues |
Burns Member Since: 02 Nov 2014 Location: Shropshire Posts: 29 ![]() ![]() ![]() |
Ok, time to start, due to my circumstances I only get a couple of hours in the morning to mess about but here's todays
Royrw Member Since: 12 Nov 2014 Location: Glasgow Posts: 46 ![]() ![]() ![]() |
Good Luck |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Roy,
hi Guyzer
Cheers Roy,
I allready had the new head unit in before I knew I would loose the top screen so that is why I had to double up the wires so both units were powered up at the same time hence soldered on so not to mess with what was working... aftermarket wiring harness that includes steering wheel controls.
As Roy shows on his pictures connects2 also do amp bypass looms that just plug in, have a look on their site they may have what you want
Burns where is you're updates?? you not done the mod yet ? |
Thanks Lads |
Guyzer
Roy, yeah, I've got the 6 disc changer so I think so... ![]() I'll try get a photo of the plug to show you. Looks like I'll have to find a work around. Cheers Guy 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
Guyzer
Roy, I'm confused also. But I'm guessing the other end of the cables you cut are connected to the audio out of your new stereo?
I technically never cut any original cables as I got my connect 2 harness so basically plug out old HU connect new Harness (connect 2) plug into new HU then double the connections up that were originally in the RR HU to the connections drawing I have mentioned (excluding sound) to RR "original" HU so both work as normal but no sound output from the RR HU |
