Home > In Car Electronics > In Car Head unit replacement issues |
Burns Member Since: 02 Nov 2014 Location: Shropshire Posts: 29 |
Ok, time to start, due to my circumstances I only get a couple of hours in the morning to mess about but here's todays
Sat Dec 27 2014 11:04am |
Royrw Member Since: 12 Nov 2014 Location: Glasgow Posts: 46 |
Good Luck Range Rover Sport 2009 Stormer edition. |
Sat Dec 27 2014 11:14am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Roy,
Thu Jan 15 2015 10:42am |
hi Guyzer
Thu Jan 15 2015 10:53am |
Cheers Roy,
Thu Jan 15 2015 11:39am |
I allready had the new head unit in before I knew I would loose the top screen so that is why I had to double up the wires so both units were powered up at the same time hence soldered on so not to mess with what was working... aftermarket wiring harness that includes steering wheel controls.
Thu Jan 15 2015 11:50am |
As Roy shows on his pictures connects2 also do amp bypass looms that just plug in, have a look on their site they may have what you want
Thu Jan 15 2015 12:50pm |
Burns where is you're updates?? you not done the mod yet ? Range Rover Sport 2009 Stormer edition. |
Thu Jan 15 2015 12:54pm |
Thanks Lads I think the problem I have though is that on the Logic 7 system the audio signal is sent to the amplifier via the fibre optic cable.
Thu Jan 15 2015 1:47pm |
Guyzer
Thu Jan 15 2015 3:10pm |
Roy, yeah, I've got the 6 disc changer so I think so... if you look at the photo above I don't have any of the wires in the centre of the plug... I'll try get a photo of the plug to show you. Looks like I'll have to find a work around. Cheers Guy 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
Thu Jan 15 2015 3:19pm |
Guyzer
Thu Jan 15 2015 3:24pm |
Roy, I'm confused also. But I'm guessing the other end of the cables you cut are connected to the audio out of your new stereo?
Thu Jan 15 2015 4:31pm |
I technically never cut any original cables as I got my connect 2 harness so basically plug out old HU connect new Harness (connect 2) plug into new HU then double the connections up that were originally in the RR HU to the connections drawing I have mentioned (excluding sound) to RR "original" HU so both work as normal but no sound output from the RR HU
Thu Jan 15 2015 4:44pm |
