![]() | Home > In Car Electronics > In Car Head unit replacement issues |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
I'm currently getting a picture as I drive along! |
Sim Member Since: 02 Oct 2016 Location: London Posts: 13 ![]() ![]() ![]() |
This looks so good I can't wait to do mine, although I am weary of doing it myself! |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Question for anyone that has changed the head unit to one of those pioneer units (or similar) are you able to use google maps from your phone on the head unit screen?
chubnut Member Since: 15 Dec 2015 Location: Pulborough Posts: 2 ![]() ![]() ![]() |
Just recently changed my head unit to the Pioneer AVH-X3800DAB and have gone with the IncarTec nav retention so have the clock reset issue. Can you tell me which IID tool you use to do the clock reset? Cheers in advance |
did you manage to find correct reverse feed wire to sort this? TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Ziggy Member Since: 14 Jun 2017 Location: UK Posts: 12 ![]() ![]() ![]() |
Does anyone know the wiries that need to be reconnected to activate the sub in the boot?
I think from memory it was the pink pairs in the incartec lead
Hi thanks for the reply, could you tell me where excatly they need to be connected upto? Also do I need a seperate amp to power them? Thanks |
If you have the incartec lead then the pink wires are obvious. If not then no idea sorry as dont know how you are connecting a new stereo. The sub was originally powered by amp under drivers seat that is no longer used in my system
Yeah I had a look at your thread. I have the incartec wiring kit so the pink wire's are there.
Head unit to amp to pink wires |
New_RRS_Guy Member Since: 18 Dec 2018 Location: Decatur,AL Posts: 2 ![]() ![]() ![]() |
I realize this the quite a bit late, what did you do to keep the factory nav (Olly-ibiza)? I can’t fogure it out. |
In Car Tec (Site Advertisers) provide this information (Page 2)
Thank You Pufftmw!! |
