Home > In Car Electronics > In Car Head unit replacement issues
Page 1 of 12 123 ... 101112>
Royrw
United Kingdom 2009 Range Rover Sport TDV6 HST Santorini Black
Shocked
Hi Guys this is my first post I have taken the plunge to join up since I have had my car for a year now & getting adventuress.
Basically I have installed the new pioneer system with apple CarPlay the AVIC-F960BT & have lost my original Satnav screen due to it all being integrated etc..,etc. & wanted to know what anyone has Installed instead of the original screen which is now blank.
I was thinking of a revers camera with screen but as the pioneer has the faculty to do this I was looking for other ideas.
Please !
Thanks in advance & please be gentle Razz
Post #442302 Wed Nov 12 2014 11:24am
triplemmm
Hi Roy
I put a TomTom in front of my now defunct screen. I'm much happier with it.
I did look at the feasibility of having another screen installed which could output something else, but as you said, the head unit does it all anyway.
Post #442377 Wed Nov 12 2014 10:27pm
Olly-ibiza
Iv just installed a Double din JVC DVD head unit and I kept my top screen and sat nav connected
Post #442378 Wed Nov 12 2014 10:28pm
Olly-ibiza
And I kept the steering wheel connected to the loom too so I have control over all the settings
Post #442379 Wed Nov 12 2014 10:29pm
Royrw
thanks guys, I have seen the picture with the TomTom in front of the original screen but my new pioneer has Satnav so didn't see the point in that for me.
I was unable to keep the top screen working due to the removal of the original head unit due to the fiber optics... so how did you keep your screen working as at the moment the Satnav DVD & Screen still have power as I have not removed them yet ?
Post #442390 Thu Nov 13 2014 5:05am
Guyzer73
How about a 7 or 8" tablet?? It would compliment the head unit and allow you to have navigation without sound on one screen and something else on the other... 2006 RRS S/C CONSTANTLY under modification...
Post #442395 Thu Nov 13 2014 7:04am
Royrw
That's a good shout regarding the tablet, I have seen pictures of this but not sure how easy this would be to install / remove and make it look good !
Post #442396 Thu Nov 13 2014 7:15am
Guyzer73
It's a fairly easy job, plenty of threads on here, including for the iPad mini. Important is to find one that fits. I know that sounds daft but different tablets fit better or worse. An example is the Note 8.0 from Samsung and the iPad mini, both 8" screens but the iPad mini fits and the Note doesn't, or least not without cutting huge bits out of the AC ducts on both sides.
The older Nexus 7 also fits better than the new Nexus 7. I fitted a Tab 7.7 with the dock connector, which was a perfect fit, but decided against it as because it was meant to be my primary screen and interface and I felt the distance to great and I had to 'reach' to operate it. That's why I went for installing my phone on the leading edge of the plastic surround:
Just Google "tablet install in Range Rover Sport" and you'll find plenty of ideas and directions. I quite like this install, but the finishing would need to be better around the 'slots' and the dock connector to give a more OEM feel to it:
http://jonlove.co.uk/2013/05/03/nexus-7-an...ver-sport/
Hope that gives you some inspiration Wink
Post #442398 Thu Nov 13 2014 7:35am
Royrw
Excellent !
Thanks for all the info !
it helps a lot !! Thumbs Up
Post #442399 Thu Nov 13 2014 7:39am
Guyzer73
No probs Royrw Thumbs Up
Another thing to bear in mind is that if I'm not mistaken on Android tablets with later operating systems, I think 4.2 you can no longer get audio out through the micro USB port, therefore you'll have to use either a BT receiver connected to the AUX in of your stereo, or hard wire it from the 3.5mm jack.
With the hard wire option you obviously will need more space useless you hack the jack to bits to get a very tight 90 degree bend... Same goes for the mirco USB for the power really.
Here's the iPad mini install from Scottypaul:
http://www.rrsport.co.uk/forum/topic32419.html?highlight=ipad
Post #442400 Thu Nov 13 2014 7:49am
Olly-ibiza
Do you have a Harmon system in yours?
Post #442401 Thu Nov 13 2014 7:54am
Guyzer73
Olly are you asking me or the Royrw? I've got the Hardon Kardon system.
Post #442403 Thu Nov 13 2014 8:00am
Royrw
I had the standard head unit with Bluetooth for phone connection only, the AUX wires had not been connected to the back of the unit's harness so it had to go but not sure weather I can get the old screen up & running with coupling the fibre optics together ?? & does anyone know where I can get a picture of the back of the screen to see what the inputs are ??
Post #442407 Thu Nov 13 2014 8:42am
Guyzer73
Here you go:
Bottom middle with the orange cables is the FOC connector for the MOST.
Top right are the 3 FAKRA input connectors for 1) Companion Cam, 2) Reversing camera and 3) TV I think. Not sure which order either I'm afraid.
The grey and blue connectors I can't help you with, but guess the grey is power and CAN-BUS etc, blue GPS??
Regards
Post #442412 Thu Nov 13 2014 10:00am
Royrw
Thanks again !! Very Happy
Post #442414 Thu Nov 13 2014 10:17am
