Home > In Car Electronics > In Car Head unit replacement issues
Page 5 of 12 <123 456 ... 101112>
Royrw
United Kingdom 2009 Range Rover Sport TDV6 HST Santorini Black
Hi Burns
the Fibre optic cable mod is basically you have to extend one of the cables for it to reach out further than behind the head unit.
Basically the original & the new cable both have keys in the centre of them that need pushed out so you can remove the FO cables remove just one on each cable & extend with the black box olly asked us to order remembering to lock it down.
I have shown this in one of my photos. :
Good Luck Range Rover Sport 2009 Stormer edition.
Post #446421 Fri Dec 26 2014 9:22am
Burns
United Kingdom 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Ok, time to start, due to my circumstances I only get a couple of hours in the morning to mess about but here's todays
Take apart the head unit to leave just the required part, then
Sort out the wires that are needed to keep the top display alive
That's all for today Diesel sport BAS remapped by Bodsy
390 Bhp SLK 55 AMG
H D Softail Slim Milwaukee 8
I like “V’s” 😎
Post #446461 Sat Dec 27 2014 12:04pm
Royrw
Good Luck Thumbs Up Range Rover Sport 2009 Stormer edition.
Post #446462 Sat Dec 27 2014 12:14pm
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Roy,
Do you have a diagram of what wires you spliced into to get audio through the existing amplifier? I've realised that when I disassemble the head unit it won't remain in the state I need (EG Power On and Aux In selected) so will have to get a crossover type unit to split the 2 channel output from the DAC to a 6 channel output for the amplifier.
The 6 channels being
2 for the Sub
2 for L&R front speakers
2 for L&R rear speakers
For information I have the Harman Kardon Logic 7 system....
Thanks in advance Thumbs Up
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #448528 Thu Jan 15 2015 11:42am
Royrw
hi Guyzer
the connections on my drawing are the only connections you require to get the screen back up & running only I do not require the sound from the RR unit as my new one has SatNav etc I only wanted the screen back up instead of an ugly dark useless screen, although I have still to kill the power to it at midnight Rolling Eyes as I have no buttons to set the clock.
so the other wires in the middle of the connector block do your speakers etc !!
ignore the wire colours as it varies between cars !!!
just the connections matter !
Hope this helps ! Feel free to ask !
Ps the original SatNav still works but no sound ! Range Rover Sport 2009 Stormer edition.
Post #448531 Thu Jan 15 2015 11:53am
Guyzer73
Cheers Roy,
But how did you get the audio from your new HU to go through the amp? I presume you've got the HK Logic 7 system?
Post #448537 Thu Jan 15 2015 12:39pm
Royrw
I allready had the new head unit in before I knew I would loose the top screen so that is why I had to double up the wires so both units were powered up at the same time hence soldered on so not to mess with what was working... aftermarket wiring harness that includes steering wheel controls.
Post #448539 Thu Jan 15 2015 12:50pm
Burns
As Roy shows on his pictures connects2 also do amp bypass looms that just plug in, have a look on their site they may have what you want
www.connects2.co.uk
I've still not got around to finishing my install yet Big Cry Diesel sport BAS remapped by Bodsy
390 Bhp SLK 55 AMG
I like “V’s” 😎
Post #448544 Thu Jan 15 2015 1:50pm
Royrw
Burns where is you're updates?? you not done the mod yet ? Whistle Range Rover Sport 2009 Stormer edition.
Post #448546 Thu Jan 15 2015 1:54pm
Guyzer73
Thanks Lads Thumbs Up I think the problem I have though is that on the Logic 7 system the audio signal is sent to the amplifier via the fibre optic cable.
I have found plenty of adapters for LRs that state "NOT FOR LAND ROVERS WITH ON FACTORY FITTED AMPLIFIERS" which I have, so kind of stumped right now.
May need to test and see if the HU will function when stripped down and also whether it retains settings once disconnected and reconnected. If so then I can set it up to be powered and in AUX IN mode and carry on as planned. If not I'm not sure how to proceed as if it defaults to of the Aux In signal won't get through to the amp...
Any ideas would be welcome.
Cheers Thumbs Up
Post #448548 Thu Jan 15 2015 2:47pm
Royrw
Guyzer
I never had any of these problems but not sure if that is because my HU was a single cd & you have a 6 cd unit ? Range Rover Sport 2009 Stormer edition.
Post #448558 Thu Jan 15 2015 4:10pm
Guyzer73
Burns wrote:
Roy, yeah, I've got the 6 disc changer so I think so... Neutral if you look at the photo above I don't have any of the wires in the centre of the plug...
I'll try get a photo of the plug to show you.
Looks like I'll have to find a work around.
Post #448560 Thu Jan 15 2015 4:19pm
Royrw
Guyzer
I am a bit confused as the picture you show is the same plug I am talking about on mine but as per my drawing I never connected any thing to the wires in the middle which is your speakers etc !!
Here is mine before I touched it !
Post #448561 Thu Jan 15 2015 4:24pm
Guyzer73
Roy, I'm confused also. But I'm guessing the other end of the cables you cut are connected to the audio out of your new stereo?
Post #448564 Thu Jan 15 2015 5:31pm
Royrw
I technically never cut any original cables as I got my connect 2 harness so basically plug out old HU connect new Harness (connect 2) plug into new HU then double the connections up that were originally in the RR HU to the connections drawing I have mentioned (excluding sound) to RR "original" HU so both work as normal but no sound output from the RR HU Big Cry
hope that helps Thumbs Up Range Rover Sport 2009 Stormer edition.
Post #448565 Thu Jan 15 2015 5:44pm
