Home > Maintenance & Modifications > EGR blanked today
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
EGR blanked today
had both my EGR valves blank off today ,very happy with the result no sluggish pull off when cold , starts better from cold , no more black smoke and the engine feels like it revs cleaner very happy I recommend you all do it
Post #463379 Sun May 31 2015 5:13pm
Wayneclarke
where did you get it done mate and how much did it cost if you don't mind me asking
Post #463381 Sun May 31 2015 5:30pm
hard2beat2014
£16 off ebay 1 hour to fit if your good with a spanner
Post #463382 Sun May 31 2015 5:34pm
Lost for Words
To add some more info for others reading - The physical blanking alone is suitable only for EU3 engines (06MY and earlier). Later, EU4 (07MY or later) vehicles need an additional software modification (often done with a remap), but, they can be blanked (and should be IMO). Smile Thumbs Up Visiting from DISCO3.CO.UK
Post #463421 Mon Jun 01 2015 8:41am
SRE
Spain
Don't forget to remove the throttle butterfly. Loads of info on here and the Disco 3 forum. Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #463425 Mon Jun 01 2015 9:47am
Gornal Hills
Hi , what year is your sport ?? , I have an 07 but it will need to be tweeked as the EML will illuminate I believe Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #463447 Mon Jun 01 2015 3:28pm
R12345a
United Kingdom 2005 Range Rover Sport TDV6 SE Zermatt Silver
Hi, I blanked my EGR valves about 6 months ago but didn't take out the throttle butterfly. Is this necessity? All I done was take out the two pipes and place the plates in place of where the holes were. Purchased the blanking plates of eBay.
Post #463450 Mon Jun 01 2015 3:45pm
SRE
Spain
You should take out the throttle butterfly, A good garage or someone who understood the system should have explained this to you. There is a danger that you could pull oil over, resulting in an engine runaway. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #463453 Mon Jun 01 2015 3:54pm
Disco_Mikey
It will, but the EML can be mapped out, allowing blanking Thumbs Up
Post #463465 Mon Jun 01 2015 4:54pm
Gornal Hills
Hi Mikey, thanks for that, I was on the understanding I would need emulators fitting but if a map tweek will suffice with blanking then great news. Can I ask , do the pipes stay or go with this ?? Confused Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #463466 Mon Jun 01 2015 5:01pm
Disco_Mikey
Either will do. Personally, I blank and leave the pipes in place. Keeps it looking completely standard under the bonnet Thumbs Up
My understanding is even with emulators, you still need a software modification, and there are only a handful of people who can do the required software...
May as well only do the software part, and save on the cost of emulators Thumbs Up
Post #463468 Mon Jun 01 2015 5:08pm
Disco_Mikey
May be worth dropping a PM to site sponsor Alive Tuning. They have an agent not far from yourself, who will be able to blank your EU4 Thumbs Up
Post #463469 Mon Jun 01 2015 5:10pm
Morgi27
Did mine a week ago and all's well I left pipes on and just
Blanked underneath them with the original gasket
Fairly easy to do although tAking the motor that operates the butterfly valve off
Is tricky an very tight to get a torx head in! I have a flexible socket which made it easy
Other than that job well done
Post #463674 Wed Jun 03 2015 1:39pm
Gornal Hills
Hi Mikey, thanks very much once again for the spot on info, I have used Gary at Alive for a number of parts and info so will keep that in mind, especially that I have someone local to me who can do this, cheers Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #463701 Wed Jun 03 2015 7:06pm
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Had my remap done by Gary from Alive Tuning......I'm still grinning!
Gaz. I was born with a photographic memory. Shame it didn't develop!
".....do you boys know what the word Nemesis means?...."
2007 2.7 TDV6 in Stornaway Grey.
EGR Blanked.
Re-mapped by Alive Tuning.
Post #464329 Thu Jun 11 2015 4:54pm
