![]() | Home > Maintenance & Modifications > EGR blanked today |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi Gaz, did you travel all the way up there ?? or do we have options ?? |
Hi Gaz, thanks for the info and explanation, sounds quite an easy process now. When it comes to the EGR side did you just blank them or do the pipe removal altogether ? and did the map cure the EML on the dash problem ? thanks in advance, this is one thing I want to get right.. |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 ![]() ![]() ![]() |
A forum member helped me blank off my EGR's and removed the pipes altogether.
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 ![]() ![]() |
Good to hear it's still going strong, Gaz. |
Thanks again Gaz, its all making sense to me now. ![]() |
Still going strong mate! ![]() ".....do you boys know what the word Nemesis means?...." 2007 2.7 TDV6 in Stornaway Grey. EGR Blanked. Re-mapped by Alive Tuning. |
