Home > Maintenance & Modifications > EGR blanked today |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
where did you get it done mate and how much did it cost if you don't mind me asking |
Sun May 31 2015 5:30pm |
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 |
£16 off ebay 1 hour to fit if your good with a spanner |
Sun May 31 2015 5:34pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
To add some more info for others reading - The physical blanking alone is suitable only for EU3 engines (06MY and earlier). Later, EU4 (07MY or later) vehicles need an additional software modification (often done with a remap), but, they can be blanked (and should be IMO). Visiting from DISCO3.CO.UK
Mon Jun 01 2015 8:41am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Don't forget to remove the throttle butterfly. Loads of info on here and the Disco 3 forum. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon Jun 01 2015 9:47am |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi , what year is your sport ?? , I have an 07 but it will need to be tweeked as the EML will illuminate I believe 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Mon Jun 01 2015 3:28pm |
R12345a Member Since: 05 Apr 2014 Location: Manchester Posts: 22 |
Hi, I blanked my EGR valves about 6 months ago but didn't take out the throttle butterfly. Is this necessity? All I done was take out the two pipes and place the plates in place of where the holes were. Purchased the blanking plates of eBay. |
Mon Jun 01 2015 3:45pm |
You should take out the throttle butterfly, A good garage or someone who understood the system should have explained this to you. There is a danger that you could pull oil over, resulting in an engine runaway. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon Jun 01 2015 3:54pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
It will, but the EML can be mapped out, allowing blanking |
Mon Jun 01 2015 4:54pm |
Hi Mikey, thanks for that, I was on the understanding I would need emulators fitting but if a map tweek will suffice with blanking then great news. Can I ask , do the pipes stay or go with this ?? 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Mon Jun 01 2015 5:01pm |
Either will do. Personally, I blank and leave the pipes in place. Keeps it looking completely standard under the bonnet
Mon Jun 01 2015 5:08pm |
May be worth dropping a PM to site sponsor Alive Tuning. They have an agent not far from yourself, who will be able to blank your EU4 |
Mon Jun 01 2015 5:10pm |
Morgi27 Member Since: 31 Jan 2015 Location: Birmingham Posts: 88 |
Did mine a week ago and all's well I left pipes on and just
Wed Jun 03 2015 1:39pm |
Hi Mikey, thanks very much once again for the spot on info, I have used Gary at Alive for a number of parts and info so will keep that in mind, especially that I have someone local to me who can do this, cheers 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Wed Jun 03 2015 7:06pm |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 |
Had my remap done by Gary from Alive Tuning......I'm still grinning!
Thu Jun 11 2015 4:54pm |
