![]() | Home > Maintenance & Modifications > EGR blanked today |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
where did you get it done mate and how much did it cost if you don't mind me asking |
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 ![]() ![]() ![]() |
£16 off ebay 1 hour to fit if your good with a spanner |
To add some more info for others reading - The physical blanking alone is suitable only for EU3 engines (06MY and earlier). Later, EU4 (07MY or later) vehicles need an additional software modification (often done with a remap), but, they can be blanked (and should be IMO). |
Don't forget to remove the throttle butterfly. Loads of info on here and the Disco 3 forum. |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi , what year is your sport ?? , I have an 07 but it will need to be tweeked as the EML will illuminate I believe |
R12345a Member Since: 05 Apr 2014 Location: Manchester Posts: 22 ![]() ![]() ![]() |
Hi, I blanked my EGR valves about 6 months ago but didn't take out the throttle butterfly. Is this necessity? All I done was take out the two pipes and place the plates in place of where the holes were. Purchased the blanking plates of eBay. |
You should take out the throttle butterfly, A good garage or someone who understood the system should have explained this to you. There is a danger that you could pull oil over, resulting in an engine runaway. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
It will, but the EML can be mapped out, allowing blanking ![]() |
Hi Mikey, thanks for that, I was on the understanding I would need emulators fitting but if a map tweek will suffice with blanking then great news. Can I ask , do the pipes stay or go with this ?? |
Either will do. Personally, I blank and leave the pipes in place. Keeps it looking completely standard under the bonnet |
May be worth dropping a PM to site sponsor Alive Tuning. They have an agent not far from yourself, who will be able to blank your EU4 |
Morgi27 Member Since: 31 Jan 2015 Location: Birmingham Posts: 88 ![]() ![]() ![]() |
Did mine a week ago and all's well I left pipes on and just
Hi Mikey, thanks very much once again for the spot on info, I have used Gary at Alive for a number of parts and info so will keep that in mind, especially that I have someone local to me who can do this, cheers ![]() |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 ![]() ![]() ![]() |
Had my remap done by Gary from Alive Tuning......I'm still grinning!
