Home > Technical > Transmission noise
Page 4 of 9 <123456789>
canaryman
Germany 2006 Range Rover Sport TDV6 SE Cairns Blue
Hi Angel,
when you see your dealer on Monday, tell them about my problems and Auto Konig, etc etc. I have nearly finished the letter and I will be sending an English version to the UK and a German version to whoever I need to in Germany!! Let me know how you get on!! (who is your dealer that you are using so I can let this end know and maybe they can liaise with each other(two dealers are better than one I guess) Smile
Post #52697 Sun Sep 03 2006 10:00am
sure
Post #52699 Sun Sep 03 2006 10:34am
OK Canaryman i dont care anymore about the noise they gave me a FFRR as a courtesy car Smile
Post #52845 Mon Sep 04 2006 9:09am
canaryman
What is an FFRR?
Post #52852 Mon Sep 04 2006 9:23am
Full Fat Range Rover.... Very Happy
Post #52857 Mon Sep 04 2006 9:30am
HA ! Laughing
Post #52862 Mon Sep 04 2006 9:34am
Ok Matt:
they took the new particle filtre off (was broken) and refixed to old kat - i will get a new one in 3 days. Rolling Eyes
for the transmission noise: will look at it in 3 days Rolling Eyes (they hear the noise) and if there is no cure ,they will call a LR technician. Rolling Eyes
stupidness is a world wide disease..... Smile
Post #52963 Mon Sep 04 2006 3:37pm
canaryman
Hi Angel,
any news on the cause of your "gerausch" or are you still hurtling around in your FFRR Smile ?
Post #53954 Fri Sep 08 2006 8:48am
Very Happy nah i have to bring the car next week wendsday to the dealer again -
BTW you should read this...:
"A customer may report a concern that a mild engine power surge or a mild vibration similar to an engine misfire can be felt at certain (not all) constant road speeds. The noise may also be described as a noise from auto transmission (scrape or chain noise in all gears). This noise can be induced by revving the engine in neutral (N) and the pipes to/from the fuel filter will be seen to vibrate. In some cases, diagnostic trouble code (DTC) P2292 'Injector Pressure Erratic' can be logged in the control module.
Cause: The fuel filter pipe connections have been incorrectly connected (during vehicle build or during maintenance and repair), which results in reverse fuel flow through the fuel filter element (large pipes crossed), or cause high back-pressure in the high-pressure fuel pump (small pipes crossed). If the fuel tank air-bleed and high-pressure fuel pump return via the fuel cooler is crossed, the resulting pressure fluctuations cause the fuel pipes to vibrate, leading to the above complaint."
Post #54042 Fri Sep 08 2006 10:29am
canaryman
Thanks for tip Angel. The only thing that is different with the noise I have is that it cannot be induced by revving in neutral. Anyway I will contact the dealer and let them know. Have you got a bulletin number for your quote??
Let me know what they say to you on Wednesday.
thanks
Post #54942 Tue Sep 12 2006 10:26am
sure i think it was A036
Post #54975 Tue Sep 12 2006 1:22pm
A036 is one of the VEP bulletins (the other being A034)....
So if you book you car in for the VEP work, this will be done for you. That's not to say it's the cause of your problems of course Very Happy
Post #54977 Tue Sep 12 2006 1:29pm
canaryman
Hello Angel,
Good luck with getting your car sorted today. Mine goes in on Monday and Tuesday to have the cruise control sorted out (for the second time). I will mention the bulletin you quoted and see if they can have a look at it.
Could you let me know the name of your dealer so that my lot can have a chat to them about the problem..........many hands make light work (unless it is a landrover light!!! Laughing )
Post #55122 Wed Sep 13 2006 8:39am
The service dealer = Schwabengarage in Stuttgart (Mr. Taxis) phone 0711 - 280301
Post #55146 Wed Sep 13 2006 9:28am
canaryman
Brilliant thanks for your help. My place is Auto Konig and it is Herr Durschler on 08121 427 181 Very Happy
Post #55152 Wed Sep 13 2006 9:33am
