Home > Technical > Transmission noise
Page 8 of 9 <123456789>
)/&!$&"%$!/("&)(!"()§/(!§&/( Evil or Very Mad sucks !
Post #96581 Fri Mar 23 2007 8:39am
Nutty Nige
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
That is real bad news C
I am shocked I thought it was a tested fix
The next question would be is there a software mod on the way to go with the transmission re-build, because if you change the type of material on the clutch linings you almost always have to modify the presure
I would guess ZF have gone back to the drawing board then.
Good luck Surprised You don't stop playing because you get old, You get old because you stop playing.
07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old.
RS Cosworth 4x4 Stage 2 Mint for summer
Audi TT
Astra VXR for the daughter.
Post #97373 Mon Mar 26 2007 8:16am
Lateral5
Australia
Any updates on the rasp Canaryman? Mine has it pretty bad and they loaded some other software patch which did nothing. RRS TDV6 Bluetooth, VR, Roof
Post #107369 Mon May 07 2007 11:58am
for me it sounds like a differential noise...
Post #107596 Tue May 08 2007 8:24am
arsi
Finland
Your symptoms are almost identical than what I have in my D3.
Gearbox in my D3 has also been changed. No change to the noise.
See my thread on the other site:
http://www.disco3.co.uk/forum/post155017.html#155017
Post #107599 Tue May 08 2007 8:31am
Lateral5
Australia
Impressive sound research on the D3 site arsi!
Best comparison I can come up with is that mine just sounds like a heat shield rattling/ vibrating. It is most noticeable under load and using transmission in Sport mode. It builds up at higher rev ranges, then disappears momentarily as you change up a gear and then reappears. It is least noticeable in 6th gear and most noticeable in 4th and 5th.
I've had so many noises and vibrations, this one is just another..... Thud RRS TDV6 Bluetooth, VR, Roof
Post #107651 Tue May 08 2007 10:07am
Lateral5
Australia
and that post, ladies and gentlemen, brings up the 200 for L5.....a gritty and patient knock RRS TDV6 Bluetooth, VR, Roof
Post #107652 Tue May 08 2007 10:08am
Post #107681 Tue May 08 2007 12:20pm
canaryman
Germany 2006 Range Rover Sport TDV6 SE Cairns Blue
Ok, my man has a bit LR meeting during June. He will meet the new area rep to discuss the rasping problem. He took me out in a LR that has the same problem. I will meet the area rep and discuss the problem with him and try to come to a resolution. LR tried to blame the fuel injectors but we are not convinced and anyway, regardless of the fault, we would like a fix. I have not given up and will let you know of any progress. Wish me luck.
By the way, now the hot weather is here, the female service staff wear less!!! Shocked (That can only be good)
Post #110117 Tue May 22 2007 3:01pm
Canary man what is *Verteilergetriebe* in english ?
cause that it what makes *zhe* noise Smile
Post #110373 Wed May 23 2007 9:37am
ivery819
zhe TRANSFER CASE Question Question Question Question
Post #110376 Wed May 23 2007 9:47am
between the front and rear axle ...
Post #110674 Thu May 24 2007 7:41am
ivery819
ja
Hunky dorey cobber...seems like old mates not on his pat malone so
now when he has a gander he won't be up the creek and he can point his stealer where to Capn Cook.
With new comic cuts he'll trundle down the track later sweet as a nut with a toothy crack in his dial and it won't cost a zac.
Post #110702 Thu May 24 2007 9:04am
Nutty Nige
Well it sounds like the old classic RR when the chain was loose in the transfer box and it was hitting the case making a rasping noise.
That reminds me of the thread on here a while ago when I said in my opinion the transfer box was the weak point when people were asking advice on a re-map on TDV8's and I made reference to the massive amount of torque after the re-map.
It will bne interesting to see if there is a later type design or updated transfer box in the near future..
Good luck with your meeting with LR Rep. Lets hope they sort it for you. Thumbs Up You don't stop playing because you get old, You get old because you stop playing.
Audi TT
Post #110705 Thu May 24 2007 9:10am
my local dealer says: *its a comfort problem but not a technical one* Rolling Eyes
Post #110760 Thu May 24 2007 11:40am
