Home > Tips & Tricks > How to replace the front seat base foam
Page 6 of 8 <12345678>
gogsy1956
Andrew, take a look at the picture showing the underside of the seat, there are 4 torn head bolts that hold it down, 2 about 6" from the front of the seat and 2 about 3" from the rear of the seat. If you look from the rear footwell you will see 2 of the bolts,,,, that will give you an idea of what your looking for from the front. You will have to remove the plastic kickplate from the front of the seat to gain access,,,,, just give it a good yank. Once the 4 bolts are out the seat Base just lifts out. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #599830 Sun Jun 07 2020 4:07pm
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
Sincere thanks for the info!! So I presume no problems with Air Bag going off and no need to disconnect the battery?!? Andrew Andrew Kennedy
Post #599836 Sun Jun 07 2020 6:52pm
gogsy1956
Nothing to worry about, I didn't disconnect the battery when I did mine,,, gives you the option to move the seat as well 2010 RRS, TDV8
22" overfinch
Post #599837 Sun Jun 07 2020 7:08pm
andrew kennedy
Many thanks.....the forum is working well!!!! Andrew Kennedy
Post #599867 Mon Jun 08 2020 12:18pm
TPS
Could do with similar instruction on how to release the seat back cover. Anyone any ideas? -----------------------------------------------
RRS SDV6 HSE MY2012 Orkney grey, Oxford leather Ivory seats Ebony carpet, Anigre wood trim, enhanced design pack.
Post #603599 Sat Aug 22 2020 11:04am
clarker63
England 2010 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
Thanks for this thread, very useful. As the seat cushions where ok, I ended up just swapping the seat bases over (moving the occupancy sensor). Whilst its not quite so nice to look at on the side, its perfectly acceptable for no cost at all.
Post #630982 Tue Feb 21 2023 9:38am
I've considered that myself. It actually makes sense to have a more flexible material on the side of the seat cushion - perhaps less likely to crack in future? 2012 SDV6 - it's missing a couple of cylinders
Post #632279 Wed Apr 12 2023 5:06pm
clarker63
Yes this material is much more flexible than the original (I dont think its leather or if it is, its very fragile) that is normally on the outside of the seat.
Post #632281 Wed Apr 12 2023 5:09pm
AndyCHO
Australia 2010 Range Rover Sport 3.0 TDV6 SE Ipanema Sand
I bit the bullet and changed my seat bases over today... thankfully I didnt offer up a sacrifice to the blood gods... I must have come close though as there are plenty of sharp edges under the seat.
I also used cable ties in place of hog rings, it will make it so much easier to repalce the foam base that is now on the passengers side when I can find one... I have my eye on one from the USA with the right cover on it as well but it is nearly A$400 delivered... It would probably cost at leat that to have it repaired and the foam bolstered by a good Motor Trimmer... this will work for me for now.
Post #632291 Thu Apr 13 2023 8:47am
JonnyCJ
If anyone’s considering this job it might be worth hoiking the full seat out. The Torx head bolts are made of cheese and very shallow. Taking the seat out is easy - 6 Torx bolts under 4 black plastic covers (2front, 4 rear). This allows much easier access and the use of penetrating fluid.
They are very tight and I’m replacing mine with Allen deep head bolts.
I’m also fitting an aftermarket heated seat kit, which is very easy and ideal if your car didn’t come with heated seats originally.
Post #633544 Sat Jun 03 2023 9:42pm
AndyCHO
My bases came out really easy... apart from the damage to my hands lol
I am interested in the aftermarket seat heater kit.... can you share a link for it?
Post #633545 Sun Jun 04 2023 1:05am
JonnyCJ
Here you go https://www.ebay.co.uk/itm/394517330511
Both seats controlled by one button.
Post #633548 Sun Jun 04 2023 6:37am
JonnyCJ
Deleted due to duplication
Post #633555 Sun Jun 04 2023 4:56pm
JonnyCJ
Pics of driver’s seat (still to do) and Overfinch adorned passenger seat.
Post #633557 Sun Jun 04 2023 7:23pm
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi Folks,
Just a quick question as I'm getting confused, with regards to the seat pad, I ordered HGB500050 but then reading this thread I should have ordered LR021399.
I amended my order but now googling the LR021399 part number, it seems to show 4 pieces of foam the fit to the seat pad and not an entire seat pad on the BritCar site
But looking at JLR Classic Parts webpage, they show LR021399 as the entire base pad.
Would someone please able to clarify which part number I need for my 2010 RRS HSE as I would like to replace the entire base seat pad.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #633686 Mon Jun 12 2023 2:32pm
