Home > Tips & Tricks > How to replace the front seat base foam |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 317 |
Sincere thanks for the info!! So I presume no problems with Air Bag going off and no need to disconnect the battery?!? Andrew Andrew Kennedy |
Sun Jun 07 2020 5:52pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
Nothing to worry about, I didn't disconnect the battery when I did mine,,, gives you the option to move the seat as well 2010 RRS, TDV8
Sun Jun 07 2020 6:08pm |
Many thanks.....the forum is working well!!!! Andrew Kennedy |
Mon Jun 08 2020 11:18am |
TPS Member Since: 12 Oct 2015 Location: Buckinghamshire Posts: 127 |
Could do with similar instruction on how to release the seat back cover. Anyone any ideas? -----------------------------------------------
Sat Aug 22 2020 10:04am |
clarker63 Member Since: 10 Feb 2023 Location: Devon Posts: 16 |
Thanks for this thread, very useful. As the seat cushions where ok, I ended up just swapping the seat bases over (moving the occupancy sensor). Whilst its not quite so nice to look at on the side, its perfectly acceptable for no cost at all.
Tue Feb 21 2023 8:38am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8974 |
I've considered that myself. It actually makes sense to have a more flexible material on the side of the seat cushion - perhaps less likely to crack in future? 2012 SDV6 - it's missing a couple of cylinders
Wed Apr 12 2023 4:06pm |
Yes this material is much more flexible than the original (I dont think its leather or if it is, its very fragile) that is normally on the outside of the seat. |
Wed Apr 12 2023 4:09pm |
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 119 |
I bit the bullet and changed my seat bases over today... thankfully I didnt offer up a sacrifice to the blood gods... I must have come close though as there are plenty of sharp edges under the seat.
Thu Apr 13 2023 7:47am |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 353 |
If anyone’s considering this job it might be worth hoiking the full seat out. The Torx head bolts are made of cheese and very shallow. Taking the seat out is easy - 6 Torx bolts under 4 black plastic covers (2front, 4 rear). This allows much easier access and the use of penetrating fluid.
Sat Jun 03 2023 8:42pm |
My bases came out really easy... apart from the damage to my hands lol
Sun Jun 04 2023 12:05am |
Here you go https://www.ebay.co.uk/itm/394517330511
Sun Jun 04 2023 5:37am |
Deleted due to duplication |
Sun Jun 04 2023 3:56pm |
Pics of driver’s seat (still to do) and Overfinch adorned passenger seat.
Sun Jun 04 2023 6:23pm |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 204 |
Mon Jun 12 2023 1:32pm |
