![]() | Home > Tips & Tricks > How to replace the front seat base foam |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 332 ![]() ![]() ![]() |
Sincere thanks for the info!! So I presume no problems with Air Bag going off and no need to disconnect the battery?!? Andrew Andrew Kennedy |
Nothing to worry about, I didn't disconnect the battery when I did mine,,, gives you the option to move the seat as well 2010 RRS, TDV8
Many thanks.....the forum is working well!!!! Andrew Kennedy |
TPS Member Since: 12 Oct 2015 Location: Buckinghamshire Posts: 127 ![]() ![]() ![]() |
Could do with similar instruction on how to release the seat back cover. Anyone any ideas? -----------------------------------------------
clarker63 Member Since: 10 Feb 2023 Location: Devon Posts: 16 ![]() ![]() ![]() |
Thanks for this thread, very useful. As the seat cushions where ok, I ended up just swapping the seat bases over (moving the occupancy sensor). Whilst its not quite so nice to look at on the side, its perfectly acceptable for no cost at all.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
I've considered that myself. It actually makes sense to have a more flexible material on the side of the seat cushion - perhaps less likely to crack in future? 2012 SDV6 - it's missing a couple of cylinders
Yes this material is much more flexible than the original (I dont think its leather or if it is, its very fragile) that is normally on the outside of the seat. |
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125 ![]() ![]() ![]() |
I bit the bullet and changed my seat bases over today... thankfully I didnt offer up a sacrifice to the blood gods... I must have come close though as there are plenty of sharp edges under the seat.
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 430 ![]() ![]() |
If anyone’s considering this job it might be worth hoiking the full seat out. The Torx head bolts are made of cheese and very shallow. Taking the seat out is easy - 6 Torx bolts under 4 black plastic covers (2front, 4 rear). This allows much easier access and the use of penetrating fluid.
My bases came out really easy... apart from the damage to my hands lol
Here you go https://www.ebay.co.uk/itm/394517330511
Deleted due to duplication |
Pics of driver’s seat (still to do) and Overfinch adorned passenger seat.
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231 ![]() ![]() ![]() |
