![]() | Home > Tips & Tricks > How to replace the front seat base foam |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 ![]() ![]() ![]() |
Hi folks,
No messing with airbags or the explosive seat belt tensioner etc, just the four bolts to undo, then unplug the heater element and lift out the base. 4th picture down is all that needs to be removed from the car. So much easier than the X5 where I had to remove the entire seat! |
Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376 ![]() ![]() ![]() |
Great 'how to' fancy doing this myself!
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 ![]() ![]() ![]() |
Great how to, think ill order a seat element and give it a go, I'm only assuming it's the element as it's the only seat that doesn't warm up and the switch lights up ok Nanocom Evo |
I'd get a new foam if I were you too- when you pull off the old heater pad, chances are you pull bit of foam off with it, especially on the bolsters! You don't want to be pulling the seat apart twice |
This is true, do you have the part numbers at all ? Nanocom Evo |
The cushion for mine is LRLR021399 and the heater element LRLR016246
Ah just noticed yours is 2011 so I'll double check cheers for the info Nanocom Evo |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9045 ![]() ![]() ![]() |
I was going to do this a few weeks ago. I got scared by the hog rings and ended up getting my indie to do it. Only cost £40 labour in the end so not too bad. I had thought about zip ties but feared they would cause problems. Should have used them! Live and learn. |
Fantastic, glad to be of service!
Yes burnt a big hole in the bolster and the inner cover of the leather Nanocom Evo |
chopperneil Member Since: 25 Aug 2015 Location: Kent Posts: 55 ![]() ![]() ![]() |
Nice write up, my drivers side bolster is sagging so may well do this myself! |
Fictivision Member Since: 31 Oct 2015 Location: Molde Posts: 31 ![]() ![]() ![]() |
Where did you buy the foam for the 2007 RRS?Can it be ordered from a webshop somewere? |
