Home > Technical > Engine oil level check |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4944 |
Add a bit of oil.
Fri Dec 23 2022 9:42am |
Crs Member Since: 04 Sep 2022 Location: Hampshire Posts: 82 |
Yes I have just put half a litre in, see how that goes, I have had to go my local Indy dealer to get the correct oil, no one else had any. |
Fri Dec 23 2022 11:57am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1167 |
No, DON"T add any oil until the car tells you to!
Fri Dec 23 2022 2:13pm |
I spoke to the garage this morning and he told me the oil level should be near the top of the oil gauge on the dash, not on the minimum mark, to be honest I never saw what it was saying to add this morning only that it was on the minimum mark, looking on line I see most people’s oil check on the dash is near the top. |
Fri Dec 23 2022 2:25pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 478 |
The manual also says to check the level with a warm engine, not a cold engine. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Fri Dec 23 2022 5:27pm |
Yes a warm engine seems to give a slightly higher oil reading |
Fri Dec 23 2022 6:03pm |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 587 |
If I remember correctly its 125ml per each increment on the dash |
Fri Dec 23 2022 8:34pm |
That sounds about right for what I had to put in |
Fri Dec 23 2022 9:03pm |
