Home > Technical > Engine oil level check
Crs
England 2013 Range Rover Sport Supercharged Autobiography Firenze Red
I went to check the oil level this this morning on my 14 plate 5lt supercharged petrol when the Engine was cold and it was on the minimum level, I took the wife to work just down the road and when I got back I left it for about 20 minutes then checked the oil level again, this time it was one mark above minimum but telling the oil level was ok, it wasn’t saying add x amount of oil so what should I do here.
Thanks
Chris
Post #629365 Fri Dec 23 2022 8:05am
Add a bit of oil.
Add however much it told you when cold ? Or bit less
Better to add in small amounts and check the next day than overfill.
Post #629368 Fri Dec 23 2022 9:42am
Crs
Yes I have just put half a litre in, see how that goes, I have had to go my local Indy dealer to get the correct oil, no one else had any.
Post #629372 Fri Dec 23 2022 11:57am
No, DON"T add any oil until the car tells you to!
IIRC, the oil level gauge displayed in the dash is the top 0.5L of the sump or so.
from the handbook:
"If the oil level is within the required operating range, the message Engine Oil Level OK will be displayed. Do not add any additional oil to the engine.
If the oil level is below the required operating range, a message advising you how much oil to add will be displayed (e.g. Add 0.5 Litre).
Add the recommended quantity of oil." --
Post #629376 Fri Dec 23 2022 2:13pm
Crs
I spoke to the garage this morning and he told me the oil level should be near the top of the oil gauge on the dash, not on the minimum mark, to be honest I never saw what it was saying to add this morning only that it was on the minimum mark, looking on line I see most people’s oil check on the dash is near the top.
Post #629377 Fri Dec 23 2022 2:25pm
NoExpert
The manual also says to check the level with a warm engine, not a cold engine. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #629381 Fri Dec 23 2022 5:27pm
Crs
Yes a warm engine seems to give a slightly higher oil reading
Post #629384 Fri Dec 23 2022 6:03pm
Red Arrow
If I remember correctly its 125ml per each increment on the dash Thumbs Up
Post #629390 Fri Dec 23 2022 8:34pm
Crs
That sounds about right for what I had to put in
Post #629391 Fri Dec 23 2022 9:03pm
