![]() | Home > General > Engine top end strip down |
Quite a bit of work.
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
Thanks Andy
No step by step guide, but now you know the parts which need to come off, could be straight forward.
If the tensioner is broken, there will be no compression on 3 cylinders I suspect if it's noisy enough to be heard while cranking, something fairly major has let go ![]() Have you made sure the cambelt and/or tensioner is in one piece? Ha she it had a new oil pump fitted? |
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 ![]() ![]() ![]() |
Hope it's simple fix mate good luck let us know how you go on |
Thanks for all the replies. The guy that is currently having a look at it and heard the noise when turning it over first hand mentioned that I might be somewhat lucky. But like you say will need to get it stripped down to see first.
Compression tests aren't easy on these engines, and I would almost say wasted work at this stage.
OK cheers. Working on getting the cambelt cover removed just now.. will update when I know a bit more. RRS 2.7 HSE Stornoway Grey
How's it going
Saga so far goes something like this...
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
You realise that if you've got bent valves that you're more than likely going to have to replace the pistons as well ?
Hence me asking what cylinder head to take off first. I will have to start checking this out from the head down, correct?
By crank I mean turning the engine over (trying to start it).
I suspect a replacement head or 2 heads will be the easiest way to go.
