Home > General > Engine top end strip down |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
Quite a bit of work.
Wed May 31 2017 8:35pm |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
Thanks Andy
Wed May 31 2017 9:06pm |
No step by step guide, but now you know the parts which need to come off, could be straight forward.
Wed May 31 2017 9:26pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
If the tensioner is broken, there will be no compression on 3 cylinders I suspect if it's noisy enough to be heard while cranking, something fairly major has let go Have you made sure the cambelt and/or tensioner is in one piece? Ha she it had a new oil pump fitted? |
Thu Jun 01 2017 4:32am |
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 |
Hope it's simple fix mate good luck let us know how you go on |
Thu Jun 01 2017 4:34am |
Thanks for all the replies. The guy that is currently having a look at it and heard the noise when turning it over first hand mentioned that I might be somewhat lucky. But like you say will need to get it stripped down to see first.
Thu Jun 01 2017 9:12am |
Compression tests aren't easy on these engines, and I would almost say wasted work at this stage.
Thu Jun 01 2017 11:06am |
OK cheers. Working on getting the cambelt cover removed just now.. will update when I know a bit more. RRS 2.7 HSE Stornoway Grey
Thu Jun 01 2017 12:39pm |
How's it going
Fri Jun 02 2017 4:06pm |
Saga so far goes something like this...
Thu Aug 10 2017 9:16am |
You realise that if you've got bent valves that you're more than likely going to have to replace the pistons as well ?
Thu Aug 10 2017 9:58am |
Hence me asking what cylinder head to take off first. I will have to start checking this out from the head down, correct?
Thu Aug 10 2017 10:11am |
By crank I mean turning the engine over (trying to start it).
Thu Aug 10 2017 10:50am |
I suspect a replacement head or 2 heads will be the easiest way to go.
Thu Aug 10 2017 11:07am |
