![]() | Home > General > Engine top end strip down |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5039 ![]() ![]() ![]() |
there's a black connector low down near battery (at back)
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
I'm still getting the F transmission message on the dash and it is in limp mode |
That's for the battery during transit when new.
what dash messages are you getting ? |
OK good... plug not required, that's good news.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4457 ![]() ![]() ![]() |
Fuel Rail Pressure Sensor |
OK cheers Mikey, and where might that plug into? as there is no other plug around that area. RRS 2.7 HSE Stornoway Grey
I think that's the cam sensor on passenger head, and would explain it
The pressure sensor on the end of the fuel rail ![]() It's not the Cam sensor. The car wouldn't start off thatbwas unplugged. And it's grey. As is the EGR connector which has 5 wires The only thing it can be is the rail pressure sensor |
That looks like the front of the engine to me with the cam belt cover.
Rail sensor is in a different location between your EU3 model and his EU4 |
Yes indeed ![]() All plugs seem to now have a home and when I started the car no 'F' gearbox message on dash for a wee while i.e. drove it a few hundred meters but it still insists in staying in limp mode and F appears intermittently. Brake switch seems OK, battery seems OK. Anything else worth checking or replacing? It's surely something electrical/software related, worth getting the codes read and deleted? RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Thanks Andy, all plugs should now be in their respective places, hopefully ![]() The christmas tree dash lights come on after a couple of minutes but if I turn car off/on the lights go out but it still is in limp mode. RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
I guess you need to think back to what you have touched.
