Home > In Car Electronics > TST Instrument Cluster Retrofit
Page 5 of 5 <12345
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Well my car is a 2012 spec face lift and the same process worked as what was used in 2010 models.
Post #633118 Wed May 17 2023 9:45am
TheWojtek
Yeah, but it's a TDV6 vs TDV8 thing.
Anyway. The cluster has arrived:
Removed the rear cover, unplugged four connectors (lift up the edges of a connector on the PCB, remove the ribbon) to the LCD screen and a small connector to the fan. Removed 5 screws holding the PCB to the display frame.
Identified the EPROM chip:
I got a successful read on 3rd try, even my superexpensive Pomona SOIC clip had trouble with sticking to all 8 pins properly:
I was really surprised (but then, once I looked up the EPROM size it explained itself) by the small size (2 kilobytes) of the dump. Is it OK?
Now I need to find a free day to work on the stock cluster. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #633120 Wed May 17 2023 10:39am
AndyCHO
Australia 2010 Range Rover Sport 3.0 TDV6 SE Ipanema Sand
2k is the correct size.
PM me a link to the .bin file and I will check it out for you.
Post #633121 Wed May 17 2023 10:48am
TheWojtek
Thanks, PM sent. Regards etc.,
Wojtek
Post #633122 Wed May 17 2023 10:59am
AndyCHO
Replied... Smile
That is the first hurdle successfully jumped
Post #633126 Wed May 17 2023 12:22pm
TheWojtek
So, finally got some time and finished the install. Possibly the first one in a 2010 TDV8.
1. Use the "instrument cluster removal and installation" section from the Workshop Manual.
2. The programming is really easy. Here is my gratitude towards @AndyCHO, great help, mate.
3. Old cluster: just remove the plastic backside and the chip is clearly in view. Read it and double check the contents. If you can see the VIN at the beginning and "AH22-..." string at the end of your dump, it is OK. Save the file, should be 2048 bytes.
4. New cluster: as mentioned in my post above, you need to dismantle the digital cluster completely, since the EEPROM chip in question is on the reverse side of the motherboard. Read the contents and save to a separate file. Should be 2048 bytes. Now duplicate this file so you have a source file from analogue cluster, a source file from digital cluster and a work file that is the copy of the digital source.
5. Combine the both - work on your copy of digital cluster file:
- The VIN is located at position 0A8: copy 17 bytes of the VIN from old cluster file to new cluster file.
- Dash type is located at position 0C0: copy 16 bytes*
- Mileage is located at position 784: copy 16 bytes*
- Immobiliser is located at position 7E8: copy 31 bytes (right to the end of file)*
6. Flash the file to the new cluster. Put it together, remember to fit all the ribbon cables and the speaker plug you had to disconnect in order to dismantle it.
7. Attach the cluster connector to the new cluster and turn the ignition on. Does it work? It should. Turn ignition off, remove the connector.
8. Trim the cluster - just dremel the bottom and side mounts off.
9. Trim the dash - the part where your new cluster speaker will go. Approx 1 cm must be trimmed, maybe more.
10. Trim the cluster surround "boomerang" piece of plastic: you will want to remove a lot from the inside part (the part that touches the transparent display protector). Just make sure you leave the clips intact and treat them as a guideline of how much to trim.
11. Fit the cluster into the dash. You will cry and swear. You will despair. It does not go through the hole provided. Don't scratch the edge of your leather dash trim that meets the "boomerang" piece. Oh, you will.
12. Make sure you don't have the display too low, make it go as high as possible to be able to read the bottom line of the cluster (range, mileage, consumption etc)
13. Fit the dash back together.
14. Use SDD (engineering mode) or GAP IID (full CCF access) to change your display mode. My cluster was from a 4.4 SDV8, it shows "diesel" on the fuel gauge right away, however the revs were up to 8000. It is reported that all clusters do it on install. Find "Scale 2" in the CCF if you have a Diesel engine, that will take care of the scale, which will now be 6000 rpm with 4000 rpm redline (BTW "Gauge Skin 2" will show "Supercharged" in the cluster, however I was not able to combine a 6000 rpm rev counter with a "Supercharged" text, which is perfectly logical and proves Solihull can indeed code something properly).
15. Enjoy. This cluster looks brilliant**.
* - I am not sure which is which, but copying from old to new did the job.
** - Everything works (ACC, Forward Safety, cruise control, offroad display) but one thing: if your car is equipped with Dynamic Mode, turning the Terrain Response dial to this mode will not be recognized by the cluster. The L322 didn't have this mode, therefore the cluster shows nothing. However, the actual mode setting works (you can see it in the 4x4 info screen on the satnav display), it is just not recognized by the L322 cluster. Regards etc.,
Wojtek
Post #633797 Sat Jun 17 2023 9:11pm
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi Wojtek, great update, lots of really useful info especially regarding the location of the mileage and immobiliser. I must get on and do mine.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #633798 Sat Jun 17 2023 9:20pm
AndyCHO
Well done... that looks really good... It isnt quite as daunting as it is made out to be but certainly isnt a doddle either.
There is now some good info and experience flowing around the forum which is always good.
Come on Craig... get your seat fixed and then the screen Smile
Post #633802 Sat Jun 17 2023 11:55pm
Jabba
Hi Andy,
Yes, that's the plan, hopefully. I'll get the part to finish the seat on Thursday and then start on the dash. Then after that it's off to the specialists for a gearbox flush and then we're off for two weeks holiday, so no playing with cars until after that.
Then I must get on with finishing the restoration of my Triumph Stag.
Many thanks
Post #633803 Sun Jun 18 2023 6:32am
Vangelion
Poland
Cześć Wojtek, odezwij się do mnie.
Post #646324 Wed Jan 15 2025 10:48pm
Page 5 of 5 <12345
