Home > In Car Electronics > TST Instrument Cluster Retrofit
Page 1 of 5 12345>
Gerd1986
So off the back of Buckster's Comment that James on the Disco3 forum had figured out how to install a TFT instrument Cluster, I'm giving it a go....
So far...
Hardware Bought
Instrument Cluster out (This was a pain in the a$$!)
Taken the data off of both EEPROM chips
Sent to James to configure
In the meantime I'm trying to compare the two to see if I can do a test in the morning...this really isn't a simple thing to do by any means. Kudos to James to figuring this out here:
https://www.disco3.co.uk/forum/range-rover...hlight=Tft
Pictures for those who are interested:
Post #567296 Fri Oct 19 2018 11:11pm
Gerd1986
Well I have the new cluster working in the car, airbag light on. car starts which shows that the panel is working otherwise it wouldn't.
James will be helping me out later on so hopefully will have it working later today.
Post #567313 Sat Oct 20 2018 10:38am
OJ2000
Following along, i have been tempted to do this on my 2010 ever since I saw the Russian videos on Youtube.
Post #567316 Sat Oct 20 2018 11:35am
DEVON
Watching this thread with great interest Bow down
Post #567323 Sat Oct 20 2018 2:04pm
Brit Plumber
Same here. Looking forward to seeing some completed examples. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #567327 Sat Oct 20 2018 3:11pm
Gerd1986
It's in......the panel underneath needs some aligning and it was an absolute pig to fit.
It looks awesome though, everything works including ACC, just need to change the rwv counter with iid tool.
Post #567328 Sat Oct 20 2018 3:16pm
Tim in Scotland
Looks good but do you have a problem in the driver info display as it looks like the graphic is corrupted - it doesn’t show any car behind the centre diff in the last 2 photos 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #567331 Sat Oct 20 2018 5:16pm
Buckster
Looks great, I admire your commitment on these type of projects Bow down Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #567332 Sat Oct 20 2018 5:19pm
Brit Plumber
I think I can see the drive train showing but it’s white and so is the roof of the RR car icon so virtually disappears 2019 5.0 SC SVA (Current)
Post #567333 Sat Oct 20 2018 5:49pm
DEVON
Looks superb , wish I had this amount of knowledge and bravery to try.
I always brake something, even doing the most simplest of tasks Rolling with laughter
You guys never cease to amaze me Bow down Bow down Bow down
Post #567334 Sat Oct 20 2018 5:54pm
Gerd1986
You right, it is there but the white on white doesn't make it very visible.
Post #567342 Sat Oct 20 2018 8:48pm
mrluke
Looks great, few questions
What programmer did you buy to read the eeprom
How much does James charge to modify the dumps ?
Does the rev counter modification require iidtool to modify the file ? or can you use ssd.
Also love the Tesla style dash . Did you contact the manufacturer to see if they would do a RHD model ?
Post #567640 Thu Oct 25 2018 6:08pm
Gerd1986
You will need these two:
https://www.amazon.co.uk/dp/B072HFDVRY?ref=yo_pop_ma_swf
https://www.amazon.co.uk/dp/B0713V5GGL?ref=yo_pop_ma_swf
PM sent about James.
I haven't used an ssd but essentially the CCF file needs to be modified, I have had to ask GAP for access to the full CCF and bootloader.
Regards: Tesla - I certainly did, I tried to get a RHD version, I tried to get the CAD files to print a RHD version and find the factory that makes them with no luck. When I get time to do mine I should have a mold that others can use also. Will keep you posted.
Post #567646 Thu Oct 25 2018 8:22pm
Laszlo
Hungary 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Re: TST Instrument Cluster Retrofit
So far...
Hardware Bought
Hi,
may I ask you to share with me / us more information about the changes and your version of RRS?
It would be great to know that, what kind of modification made with the wiring, instrument cluster connection and etc.
I am fancy to the get installed an L405 instrument cluster in RRS 2008.
Any advise much appreciated.
Post #595870 Sun Mar 01 2020 9:30pm
aaronjb
I'm glad you brought this thread back to the top, Laszlo, because otherwise I'd never have known about this excellent work by Gerd! Thumbs Up
Impressive stuff and I'd love to do the same.. maybe the mods will start once I fix all the maintenance items Laughing 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #596118 Fri Mar 06 2020 4:05pm
Page 1 of 5 12345>
