![]() | Home > In Car Electronics > TST Instrument Cluster Retrofit |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
Well my car is a 2012 spec face lift and the same process worked as what was used in 2010 models. |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Yeah, but it's a TDV6 vs TDV8 thing.
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125 ![]() ![]() ![]() |
2k is the correct size.
Thanks, PM sent. Regards etc.,
Replied... |
So, finally got some time and finished the install. Possibly the first one in a 2010 TDV8.
Well done... that looks really good... It isnt quite as daunting as it is made out to be but certainly isnt a doddle either.
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231 ![]() ![]() ![]() |
Hi Andy,
Vangelion Member Since: 15 Jan 2025 Location: Łódź Posts: 3 ![]() ![]() |
Cześć Wojtek, odezwij się do mnie. |
Done, thanks ![]() |
durgapal Member Since: 29 Apr 2025 Location: Midlands Posts: 1 ![]() ![]() |
Hi, Can I please get some hep with the VIN programming? I have the cluster and the SSD tool. I understand that the IC will not work unless the VIN is correct. SSD will not overwrite the VIN. How do I change it? Please advise. Jatin. |
