![]() | Home > In Car Electronics > TST Instrument Cluster Retrofit |
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125 ![]() ![]() ![]() |
I suggest having a good read through the Disco3 thread mentioned before.
If your clocks are like these ones (for an L320) then the process is exactly the same.https://www.ebay.com.au/itm/115743390506?fits=Year%3A2012%7CModel%3ARange+Rover+Sport&hash=item1af2d7fb2a:g:nukAAOSwRdJkHnpe&amdata=enc%3AAQAIAAAA4Ih9kJlET99CRXnatTGwO%2BU%2BD7qSK1yC4SoA6EO8swGXuUB9WA5JdFgyaUvU8x%2FdavB2e4g2G1J%2FVJcyECaFvfnb%2FXQwAl00agAR3IImsWoUevozBcsraq4t2QjHqzPS4ptZLfJP39zv5%2BX76GtNilB2FZD4BUXSS%2FLUa3VH8ixU1ODSUvTfncgMjLzE6s5dDcGS5RWPcKfT2Od9Uce43KOs8qlIFeQuSKtxA%2FCZhAqeBNbovApAkFCl%2F9ZrMhfrEqRaHB8FTctdX67CWHgKQ2qGlFZ4EfELwnKZ7mQpf0Ox%7Ctkp%3ABk9SR7CK6rfzYQ |
I will try that link again.
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231 ![]() ![]() ![]() |
Hi Andy,
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
I have just ordered a set but still to get the programming tools next, let me know what you find out |
My RRS doesnt have DSC so maybe that is the difference... the screen does show when HDC comes on and off as well as Command Shift (if you use it). So I cant help you on Dynamic mode question but my guess would be it will show it. |
Hi Andy,
Hi folks, wonder if you can verfiy this for me. I've just taken a chip reading from the tft dash prior to any other work, does this look correct, top half and bottom half nothing much inbetween:
That looks to be OK compared to mine, the next step is to get your Original Dash out, find the correct chip and grab that code.
Thanks for the confirmation Andy, much appreciated.
Hey Jabba, How did it go? i'm a step or 2 behind you but I have all the kit now, excited to get the job done. |
Hi Craig,
Well I have taken the .bin file successfully from the L322 unit, so i have caught you up.
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
VIN, dash type, immo, mileage.
