Home > General > Wheels ?
Page 2 of 3 <123>
Singletrack
Belgium 2006 Range Rover Sport TDV6 HSE Java Black
Umbertob - very correct. The 315/35 in 22" will yield an actual 74.94 mph when the speedo reads 70 mph. That's quite a variance... 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge
Post #58581 Thu Sep 28 2006 5:22pm
tf9
Russia 2006 Range Rover Sport Supercharged Java Black
You can always ask your dealer to reprogramm the speedo. 2014 Mercedes-Benz S500
2014 Range Rover Autobiography, Causeway Gray, Ivory/Ebony
2013 BMW 530d
2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. SOLD
2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit. SOLD
2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD.
Post #58658 Fri Sep 29 2006 7:31am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
One word of caution, if you ever intend to go even slightly off road, avoid 22" wheels and be wary of the 20" ones. As I have found, they do not like even tip-toeing off the tarmac onto grass. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #58659 Fri Sep 29 2006 8:30am
1stRRS
For those of you that have 22 wheels what is the correct tire size ? is it 285/35-22 or 265/35-22 ? I have some overfinch wheels on order but are available with tires size 265 not the 285. I have a supercharged that come with 275/40-20 tires. I am curious why overfinch pair up their wheels with the 265's RRS Supercharged Java Black /Ebony 1st Edition
Jakarta, Indonesia
Post #59690 Tue Oct 03 2006 4:20am
tf9
265 is for FFRR, that is for sure.
Correct size is 275-335. 2014 Mercedes-Benz S500
2013 BMW 530d
Post #59691 Tue Oct 03 2006 6:34am
285/35/22 Very Happy
Post #59712 Tue Oct 03 2006 10:01am
canaryman
Germany 2006 Range Rover Sport TDV6 SE Cairns Blue
shmoogle wrote:
Ouch! What's the legal issue then Canaryman?
Well, basically you need a T.U.V number for the wheels that will show approval for your car, without it your vehicle is illegal. The T.U.V is like a standards agency so if you have wheels that are suitable and approved that are over and above what is needed, if it has not TUV number for your car then you cannot put them on. There is a loophole, however.
My brother in law has a Ford Puma (brilliant fun to drive) and I put upgraded front brakes and pads on it. The TUV said they were illegal (despite proving to stop the car in 20% shorter distance and giving more control whilst doing so) and was told that in order to pass the TUV and make his car legal, he had to refit the old (far inferior) Ford brakes Shocked .
The brake manufacturer said that though they had no TUV number for Germany they had an ECE number that covers the EU and therefore supercedes German law. We took the documentation to the TUV, informed them of the law and they said................"Oh, you are correct so we will pass the brakes and you are road legal".
I intend to buy the wheels in the UK (with an ECE number) and tell them to stick it!!! Laughing
Post #59846 Tue Oct 03 2006 5:24pm
Ah yes, I' ve heard of the TUV. Censored ... at least there is a way round. I expect the Germans are happy to be overruled by the EU Wink
Post #59996 Wed Oct 04 2006 7:34am
Berliner
Germany 2006 Range Rover Sport Supercharged Bonatti Grey
TUV is there to protect the end consumer from cheap copies from Asia which can cause accidents... Every wheel shouldhave a TUV certificate!
Post #60039 Wed Oct 04 2006 12:49pm
Berliner
I love your Tiger wheels they look the business! They are apparently designed to Land Rover specifcation, with the same wheel bolts etc... Have you seen the Overfinch Supersport wheels? They also look fantastic!!
Post #60040 Wed Oct 04 2006 12:51pm
rrmad
285/35/22 for a 22 x 10 rim
Post #60944 Fri Oct 06 2006 7:02pm
saxman
..Post Removed..
Post #60993 Sat Oct 07 2006 8:28am
DrLex
Iceland
Saxman,
How nice it is for a kind chap to take time to register just to point out savings that forum members can make! Are there any other products and sites that you would like to recommend? I'm sure you've got some very professional photos you can <s>link to</s> post here....
Post #61170 Mon Oct 09 2006 12:35pm
Just looking at these wheel again .... kahn rsx 22"
But you can bet they will be a pig to keep clean Shocked
Post #62679 Wed Oct 18 2006 4:08pm
ryanoz
United States 2006 Range Rover Sport Supercharged Java Black
I would think that your brakes are going to wear much faster with the bigger wheels.
Post #62686 Wed Oct 18 2006 6:59pm
Page 2 of 3 <123>
