![]() | Home > General > Wheels ? |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 ![]() ![]() ![]() |
Umbertob - very correct. The 315/35 in 22" will yield an actual 74.94 mph when the speedo reads 70 mph. That's quite a variance... 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
tf9 Member Since: 07 Jun 2006 Location: Moscow, Russia Posts: 643 ![]() ![]() ![]() |
You can always ask your dealer to reprogramm the speedo. 2014 Mercedes-Benz S500
1stRRS Member Since: 19 Jun 2005 Location: Jakarta, Indonesia Posts: 13 ![]() ![]() |
For those of you that have 22 wheels what is the correct tire size ? is it 285/35-22 or 265/35-22 ? I have some overfinch wheels on order but are available with tires size 265 not the 285. I have a supercharged that come with 275/40-20 tires. I am curious why overfinch pair up their wheels with the 265's RRS Supercharged Java Black /Ebony 1st Edition
265 is for FFRR, that is for sure. Correct size is 275-335. 2014 Mercedes-Benz S500 2014 Range Rover Autobiography, Causeway Gray, Ivory/Ebony 2013 BMW 530d 2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. SOLD 2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit. SOLD 2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD. |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
285/35/22 |
canaryman Member Since: 16 Feb 2006 Location: Haag a.d amper Posts: 188 ![]() ![]() ![]() |
Well, basically you need a T.U.V number for the wheels that will show approval for your car, without it your vehicle is illegal. The T.U.V is like a standards agency so if you have wheels that are suitable and approved that are over and above what is needed, if it has not TUV number for your car then you cannot put them on. There is a loophole, however. My brother in law has a Ford Puma (brilliant fun to drive) and I put upgraded front brakes and pads on it. The TUV said they were illegal (despite proving to stop the car in 20% shorter distance and giving more control whilst doing so) and was told that in order to pass the TUV and make his car legal, he had to refit the old (far inferior) Ford brakes ![]() The brake manufacturer said that though they had no TUV number for Germany they had an ECE number that covers the EU and therefore supercedes German law. We took the documentation to the TUV, informed them of the law and they said................"Oh, you are correct so we will pass the brakes and you are road legal". I intend to buy the wheels in the UK (with an ECE number) and tell them to stick it!!! ![]() |
Ah yes, I' ve heard of the TUV. |
Berliner Member Since: 04 Oct 2006 Location: Berlin Posts: 34 ![]() ![]() ![]() |
TUV is there to protect the end consumer from cheap copies from Asia which can cause accidents... Every wheel shouldhave a TUV certificate! |
I love your Tiger wheels they look the business! They are apparently designed to Land Rover specifcation, with the same wheel bolts etc... Have you seen the Overfinch Supersport wheels? They also look fantastic!! |
rrmad Member Since: 29 Oct 2005 Location: UK Posts: 44 ![]() ![]() |
285/35/22 for a 22 x 10 rim |
saxman Member Since: 07 Oct 2006 Location: Manchester Posts: 1 ![]() ![]() |
..Post Removed.. |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 ![]() ![]() |
Saxman,
Just looking at these wheel again .... kahn rsx 22"
ryanoz Member Since: 16 Oct 2006 Location: Louisiana Posts: 32 ![]() ![]() ![]() |
I would think that your brakes are going to wear much faster with the bigger wheels. |
