Home > Faults & Fixes > RRS2 Air Con Failing
Welshian
Wales
My air con on the drivers side is not blowing cold air but it is on the passenger side, main dealer says its low gas pressure so there's a leak somewhere. If there's a leak then is seems it will be under warranty but if not and its just deterioration they want £500+ to re-gas. Is this the sort of price what you would expect as I've seen re-gassing at considerable lower prices than that. Big Cry RRS2 HSE Chile Red
1955 Morris Minor lovingly fitted every nut and bolt
Post #563575 Mon Aug 20 2018 12:30pm
geoffsnook
Just paid £120 to have min e leak tested and refilled it was 2 small o rings gone by an expert get a mobile to have a look first before committing to a big bill Thumbs Up
Post #563592 Mon Aug 20 2018 3:56pm
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
There doesn't seem to be any experts here in the Midlands, main dealer also quoted me the same price, a local air con only place did it for £150 but both say there is no leaks and they have tested it 3 times and charged me £150 each time. Mine has the same issue with driver side blowing warm and passenger side cold.
Post #563628 Mon Aug 20 2018 8:12pm
geoffsnook
Well from what you say it has lost gas as mine did this also my megane did as well and each time it was because the gas had leaked slowly so if they have done it and it no longer works then i say it has a leak and its probably the same as the one you had before Thumbs Up
Post #563630 Mon Aug 20 2018 8:18pm
the_big_1
It does sound like it but it does seem there is no where in the area that actually knows what to do with air con. They only know how to fill and charge people
Post #563632 Mon Aug 20 2018 8:20pm
geoffsnook
Mine was a mobile guy who my mate in his garage uses and he was very good as you cant substitute experience he new what it was before he got to my Renault after what i told him over the phone Thumbs Up
Post #563633 Mon Aug 20 2018 8:23pm
geoffsnook
Dont know if these guys are any good to you even if it means a bit of travel time Thumbs Up
https://www.coolcaraircon.co.uk/
Post #563634 Mon Aug 20 2018 8:25pm
the_big_1
Wish I could find someone that someone recommends after using them. After two places, costing me over £500 and no closer to the problem, I want someone that actually knows what they are doing.
Post #563635 Mon Aug 20 2018 8:31pm
geoffsnook
well if you ever come down my way i can recommend my guy but there must be someone closer to you Thumbs Up
Post #563637 Mon Aug 20 2018 8:37pm
the_big_1
I just been all over the front of the car, underbonnet with a UV light I found, no signs of anything illuminuse???
You would think in the Midlands, next to where the car was built, someone would know!
Post #563640 Mon Aug 20 2018 8:44pm
the_big_1
Hi guys,
this is what the dealer should be doing.
1 Charge the air conditioning system with nitrogen
2 Isolate the nitrogen supply
3 Monitor the pressure gauge and check for leaks for 30 minutes
Has the source of the leak been identified?
Yes
Rectify the leak as necessary. Install a new receiver drier. Using the manufacturer approved equipment, evacuate and recharge the air conditioning system with the correct quantity of refrigerant and oil
No
GO to A2.
A2: LEAK TEST 2
1 Using the Jaguar Land Rover Approved Equipment, evacuate and recharge the air conditioning system with the correct quantity of refrigerant and oil
2 Using the Jaguar Land Rover Approved refrigerant leak detector, check for a refrigerant leak
Was a refrigerant leak detected?
Yes
Using the Jaguar Land Rover Approved Equipment, recover the refrigerant. Repair the leak as necessary. Evacuate and recharge the air conditioning system with the correct quantity of refrigerant and oil
No
Repair complete
Post #563648 Mon Aug 20 2018 9:17pm
If it is cold on one side and not the other unless there are two separate air conditioning systems one for each side, how can low gas cause one side to be cold and not the other, as it is a sealed system it will either pull the temp down or it won't, and surely the actual air con system itself has no bearing on where the air is distributed to as that is controlled by the distribution flaps, blowers etc. of the heating and ventilation system. Has anybody checked the flap actuators, temp sensors, blend motor positions etc. or whatever they are called these days. I thought this could be checked using the Gap diag. tool, mind you I could be talking absolute rubbish Rolling with laughter
Post #563654 Tue Aug 21 2018 5:22am
GodivaNige
the_big_1
Take your car to Chris at Venture 4x4, Shipston on Stour armed with all the info and experiences you have had with your air con to date. The techs there know LR inside out and will sort your problem. I’m that confident with their ability, they REALLY know their stuff Thumbs Up
Post #563655 Tue Aug 21 2018 5:36am
jimbg
As I posted before there is a a topix item regarding hot air from one vent and cold from the other.
I had this problem on my Disco5 and the update fixed it. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #563674 Tue Aug 21 2018 11:27am
geoffsnook
My car did that one side cold the other not my guy said the system works with just 50 grams but will not cool but will work and as soon as he found the leak fixed it and refilled it both sides were cold again in laymans terms there is pressure/gas but not enough to cool the complete system Thumbs Up
Post #563680 Tue Aug 21 2018 1:34pm
