Home > Faults & Fixes > RRS2 Air Con Failing |
Just paid £120 to have min e leak tested and refilled it was 2 small o rings gone by an expert get a mobile to have a look first before committing to a big bill |
Mon Aug 20 2018 3:56pm |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 |
There doesn't seem to be any experts here in the Midlands, main dealer also quoted me the same price, a local air con only place did it for £150 but both say there is no leaks and they have tested it 3 times and charged me £150 each time. Mine has the same issue with driver side blowing warm and passenger side cold. |
Mon Aug 20 2018 8:12pm |
Well from what you say it has lost gas as mine did this also my megane did as well and each time it was because the gas had leaked slowly so if they have done it and it no longer works then i say it has a leak and its probably the same as the one you had before |
Mon Aug 20 2018 8:18pm |
It does sound like it but it does seem there is no where in the area that actually knows what to do with air con. They only know how to fill and charge people |
Mon Aug 20 2018 8:20pm |
Mine was a mobile guy who my mate in his garage uses and he was very good as you cant substitute experience he new what it was before he got to my Renault after what i told him over the phone |
Mon Aug 20 2018 8:23pm |
Dont know if these guys are any good to you even if it means a bit of travel time
Mon Aug 20 2018 8:25pm |
Wish I could find someone that someone recommends after using them. After two places, costing me over £500 and no closer to the problem, I want someone that actually knows what they are doing. |
Mon Aug 20 2018 8:31pm |
well if you ever come down my way i can recommend my guy but there must be someone closer to you |
Mon Aug 20 2018 8:37pm |
I just been all over the front of the car, underbonnet with a UV light I found, no signs of anything illuminuse???
Mon Aug 20 2018 8:44pm |
Hi guys,
Mon Aug 20 2018 9:17pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5001 |
If it is cold on one side and not the other unless there are two separate air conditioning systems one for each side, how can low gas cause one side to be cold and not the other, as it is a sealed system it will either pull the temp down or it won't, and surely the actual air con system itself has no bearing on where the air is distributed to as that is controlled by the distribution flaps, blowers etc. of the heating and ventilation system. Has anybody checked the flap actuators, temp sensors, blend motor positions etc. or whatever they are called these days. I thought this could be checked using the Gap diag. tool, mind you I could be talking absolute rubbish
Tue Aug 21 2018 5:22am |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
the_big_1
Tue Aug 21 2018 5:36am |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1843 |
As I posted before there is a a topix item regarding hot air from one vent and cold from the other. I had this problem on my Disco5 and the update fixed it. 2023 P440e SE Dynamic on order -cancelled 2022 HSE Dynamic P400e 2017 Discovery 3.0 HSE Silicon Silver Nimbus interior and a few extra toys SOLD 2013 HSE Black, Orkney Grey, Ebony Seats and Ivory Interior SOLD 2006 HSE Plus a few other cars inbetween! |
Tue Aug 21 2018 11:27am |
My car did that one side cold the other not my guy said the system works with just 50 grams but will not cool but will work and as soon as he found the leak fixed it and refilled it both sides were cold again in laymans terms there is pressure/gas but not enough to cool the complete system |
Tue Aug 21 2018 1:34pm |
