![]() | Home > Faults & Fixes > RRS2 Air Con Failing |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 ![]() ![]() ![]() |
Hi guys,
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
That’s correct, with a reduced charge of refrigerant, the evaporator won’t be fully flooded and will not efficiently transfer heat across the full width of the coil. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Could there be a leak in the Evaporator which is located in the heater unit, which I assume is inside the car and which I also imagine would be difficult to access to locate a leak as there would be so much stuff around it, would probably need to remove some trim to get to it. Although if the leak was inside the car you might smell it as I assume the gas has a odour to it.
Yes, the evaporator is in the cabin, within the package that contains the heater core, air direction and mixer flaps etc, mounted under the dash. An electronic refrigerant sniffer will pick up a leak from a holed evaporator when poked into one of the outlet vents.
Hope for the op's sake it's not that then, as that sounds like a lot of work and expense to replace it, hopefully would be under warranty though.
Hi guys,
Is there a way to see into the heater unit, just a little to look for any dye. Removing some trim is no problem. |
Just looked Topix and it seems the heater motor is easy to remove. Lower passager trim out then un-bolt it. I would think with the motor out, the cores would be easy to see and UV show any leaks? |
No access to view the evaporator, not without completely removing the whole heater assembly from the car, stripping it down on a bench and inspecting it.
There are no air conditioning people in the west Midlands, that's the issue. The main dealer has stated no leak, the local supposed air con experts state no leak. Both added dye, both done pressure tests. I have checked all under bonnet and no dye, not even a mark. I will remover motor in next couple of days. I would guess that if dye is leaking in the heater unit, the airflow would splash it around so should be something but costs nothing to check. |
If there is no leak and the correct charge remains in the system, assuming obvious things like you have a clear pollen filter, the heater blower fan is working ok etc etc then your problem could either be a sticking air mix flap motor on the side which isn’t cooling very well, effectively mixing warm air with the cold air you expect to feel from the vents OR you have a worn compressor which isn’t pumping efficiently. A worn compressor can give the same symptoms as a system low on gas, hence why it’s important to rule out a leak first by weighing out as suggested. A worn compressor is determined using a manifold gauge.
Looking at Topix, if the dealer do the tests as instructed, they should run the car with high and low pressures measured etc so should show compressor issues. Pollen filters done a month or so ago at service.
Why not simply check to see if the HVAC Control Module software has been updated, if not have it done. If still no different have the stepper motors, flap actuators etc. calibrated which should then eliminate that side of it, if that all checks out o.k. and if still no different then start to look elsewhere. You have already been told twice there is no leak found, could have it checked and re-gassed as many times as you like it will not cure it if there is no leak, surely you need to check everything that can influence it, not just some of it. Have you tried a thermometer in the vent which is blowing cold and see what it pulls down to, which I imagine should be in the region of 5 or 6 degrees not sure on that though, it should however actualy be checked through the center air vent I believe. If It doesn't that may point to the A/C side, if it does then that could point to the ventilation and air distribution side.
