Home > General > Engine top end strip down
Page 13 of 13 <123 ... 111213
DerrekL
OK, hopefully nearly over the finish line hahaha Thumbs Up all the dash messages seem to have disappeared BUT car drives with no turbo, it goes through the gears eventually but no turbo/boost, seems very very flat when driving it. RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #539463 Fri Oct 27 2017 8:21pm
Well I don't know how you have done that Confused
Air leak at the top of the engine somewhere ? on parts you have touched.
Would be a significant hole though
normally it's hand work to rev engines at idle when the turbo's not doing anything, but I doubt its that bad?
Post #539498 Sat Oct 28 2017 9:06am
Disco_Mikey
Oddly, I have one in just now with what sounds like exactly the same fault Laughing
Similarly issue, cam tensioner bolt was left lose. Pistons met valves, heads damaged, reworked and refitted, been flat as a fart ever since...
Had a new turbo too, no difference
Timing is bang on, no fault codes, nothing obviously wrong with it...
Post #539558 Sat Oct 28 2017 9:00pm
Rfsci
Injectors need programmed?
Gasket thickness
Post #539615 Sun Oct 29 2017 3:24pm
You could recheck the timing, to see if its still as good as you set it to.
Post #539786 Tue Oct 31 2017 12:50pm
Have either of you had any luck?
Post #540516 Fri Nov 10 2017 11:41am
DerrekL
Went round the many things we have bolted together including pipework, air hoses etc etc; and re-tightened everything and it seemed to work as took for a drive and turbo kicked in. Engine management light still on though, possible EGR's?. Booked in for an MOT tomorrow, see how it goes Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #540537 Fri Nov 10 2017 7:47pm
