Home > General > Engine top end strip down |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
The broken bolts are the ones that hold the bearing caps on, there are 2 or 3 that look as though they were stretched to breaking point and these actually were loose enough that was able to unscrew them by hand from the head.
Mon Aug 21 2017 12:23pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4417 |
Bearing caps are line bored, and cannot be replaced individually. If this is the case, it will need a new head
Mon Aug 21 2017 8:15pm |
Cheers DM. All bearing caps are still in one piece, it was a couple of bolts holding the bearing caps that broke off. But no doubt the bearing caps will be distorted at some level after this happening, correct? RRS 2.7 HSE Stornoway Grey
Tue Aug 22 2017 7:32am |
Be a shame to put it back together, and have a bigger problem arise because of it... |
Tue Aug 22 2017 7:41am |
Yes very true. I'm just trying to gauge what would have been distorted/bumped out of place/stretched etc; when such a major break occurs. By the sounds of things it's a lot, so yeah probably looks like a head replacement. RRS 2.7 HSE Stornoway Grey
Tue Aug 22 2017 7:49am |
Found this on another post...
Tue Aug 22 2017 9:35am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4999 |
As no pistons have been changed, you simply fit the same thickness gasket that was on there already.
Tue Aug 22 2017 11:08am |
AHH!! OK. I see the markings on the original gasket, nice one Andy. Thanks RRS 2.7 HSE Stornoway Grey
Tue Aug 22 2017 12:41pm |
Will glow plugs come on 2nd hand head or is it a case of transferring them from my original head?
Tue Aug 22 2017 1:05pm |
They are a nightmare !
Tue Aug 22 2017 5:45pm |
Really, you should be measuring the cylinder head height, and piston heights to identify the correct gasket thickness... |
Tue Aug 22 2017 6:08pm |
Isn't the head flat though?
Tue Aug 22 2017 6:21pm |
With a cylinder head skimmed, it moves the valves closer to the pistons. A thicker gasket accounts for this removal of material |
Tue Aug 22 2017 7:12pm |
OK thanks Andy, will try that check when I get to it. RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Wed Aug 23 2017 7:19am |
