Home > General > Engine top end strip down
Page 6 of 13 <123 ... 567 ... 111213>
It sounds like you have been very lucky.
I'm not aware of the week points, but it sounds like the chain breaking saved most of the damage.
What about these bolts you speak off ? Can that be fixed easily ?
As you say, mark the location of the valves, roll the valves along a flat surface, refit into the same positions they came out of. Gain confidence they have sealed using liquid.
Wonder what's under the other head? perfect condition or a mess ?
Post #533399 Mon Aug 21 2017 11:12am
DerrekL
The broken bolts are the ones that hold the bearing caps on, there are 2 or 3 that look as though they were stretched to breaking point and these actually were loose enough that was able to unscrew them by hand from the head.
I will need to inspect all the working parts a bit closer and hopefully be able to get some new bolts for the bearing caps and/or replace the bearing caps. So far the damage I visibly see is 2/3 bearing cap bolts and a couple of the rockers.
Yes, indeed. Will be opening head number 2 (drivers side) as soon as I get this side sorted out. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533410 Mon Aug 21 2017 12:23pm
Disco_Mikey
Bearing caps are line bored, and cannot be replaced individually. If this is the case, it will need a new head
The camshafts are also hollow. I don't imagine it would take a great deal of force to distort them...
Post #533450 Mon Aug 21 2017 8:15pm
DerrekL
Cheers DM. All bearing caps are still in one piece, it was a couple of bolts holding the bearing caps that broke off. But no doubt the bearing caps will be distorted at some level after this happening, correct? RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533463 Tue Aug 22 2017 7:32am
Disco_Mikey
Be a shame to put it back together, and have a bigger problem arise because of it...
Post #533468 Tue Aug 22 2017 7:41am
DerrekL
Yes very true. I'm just trying to gauge what would have been distorted/bumped out of place/stretched etc; when such a major break occurs. By the sounds of things it's a lot, so yeah probably looks like a head replacement. RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533469 Tue Aug 22 2017 7:49am
DerrekL
Found this on another post...
How does this bode for me replacing with 2nd hand head?
Does a 2nd hand head need skimmed?
What size head gasket required, as I believe there are 5 sizes. Is there a way/process to determine what size head gasket I require i.e. how do I find out what the maximum piston protrusion is? RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533482 Tue Aug 22 2017 9:35am
As no pistons have been changed, you simply fit the same thickness gasket that was on there already.
It is identified by how many notches (or protrusions) are on the end of the head gasket.
Post #533485 Tue Aug 22 2017 11:08am
DerrekL
AHH!! OK. I see the markings on the original gasket, nice one Andy. Thanks Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533490 Tue Aug 22 2017 12:41pm
DerrekL
Will glow plugs come on 2nd hand head or is it a case of transferring them from my original head?
If I need to transfer them how difficult is this to do. I have read a post (I think on here) that the guy had a mare trying to drill them out! RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533497 Tue Aug 22 2017 1:05pm
They are a nightmare !
They will come with the head as no used sales person would dare remove them lol
Obviously you could check they work. Simple resistance check first if you have a meter? Should be 1R.
If they pass that connect to 12v and see if they get hot (without burning yourself).
I find they are best to remove with the head upside down.
No point fitting used ones.
Post #533528 Tue Aug 22 2017 5:45pm
Disco_Mikey
Really, you should be measuring the cylinder head height, and piston heights to identify the correct gasket thickness...
Post #533531 Tue Aug 22 2017 6:08pm
Isn't the head flat though?
Would be interested to learn more about what tolerance this gasket thickness is trying to get around.
Post #533532 Tue Aug 22 2017 6:21pm
Disco_Mikey
With a cylinder head skimmed, it moves the valves closer to the pistons. A thicker gasket accounts for this removal of material
Post #533539 Tue Aug 22 2017 7:12pm
DerrekL
OK thanks Andy, will try that check when I get to it. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533573 Wed Aug 23 2017 7:19am
