Home > General > Engine top end strip down
Page 4 of 13 <123 45 ... 111213>
DerrekL
Andy K wrote:
if/when it comes to needing heads, I would recommend these guys.
http://www.ebay.co.uk/itm/2-7-DIESEL-CYLIN...SwurZZHXMt
More expensive than when I looked last, but see it has a chain in the pic. and cam sensor.
Cheers for the links Andy. Buying from these guys is probably the route I will end up taking once I get the head off. Thumbs Up
Just got this reply back from autoreserveparts regarding the exact head following the link you listed "It includes valves, cams and cam carriers but not the chain." so I'm assuming they mean the cam chain isn't with the head, doesn't that sound a bit dodgy? RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #532796 Mon Aug 14 2017 9:03am
DerrekL
OK, here's one for you... I read this "The drivers side cam (off side) drives the near side cam, so when the chain breaks the off side is not affected, the near side cam stops, usually with a crunch." here:
http://www.disco3.co.uk/forum/topic154075-120.html
I was planning to take the drivers side head off anyways BUT may this be the case for me also i.e. damage being done to just one head, given my original failure was the oil pump casing giving way and the tensioner collapsing. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #532799 Mon Aug 14 2017 9:44am
When I purchased one from them it didn't come with a chain.
Maybe they consider a chain isn't a second hand part you should be using.
Naughty of them to show it in the picture.
You could always do a deal and ask them to give you a chain for the same price.
Post #532805 Mon Aug 14 2017 10:41am
From memory the belt drives the outer exhaust values.
The chain drives the inner inlet valves.
Given your original failure was the cambelt tension, i'm fairly sure as least one valve would be open on the drivers side during the cycle.
You could try and find an animation video of a TDV6 to see for yourself.
In the end it comes down to 2 things
1) How much have you got to put back on the car before you try and start it. that would then need to come off again.
2) Even if it does start, one valve could be slightly leaking on the drivers side head. resulting in fault codes etc
Will explain more later/when you got the first head off
Post #532806 Mon Aug 14 2017 10:55am
DerrekL
Yes that's what I thought and it also doesn't state in the description that chain isn't attached. Anyways I will persevere with taking the LH head off just now and continue to search for another cylinder head. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #532808 Mon Aug 14 2017 11:07am
I see chain and tensioners are £110 on eBay so worth trying to do a deal with a head
Post #532809 Mon Aug 14 2017 11:35am
DerrekL
Yes I think so to. As I would have thought if you are buying the full head... well... you should get all the bits with it. It's worth watching out for/asking about when I do go to buy one. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #532815 Mon Aug 14 2017 12:49pm
DerrekL
OK, yip get what you are saying. Hopefully get the LH side completed in due course then can consider RH side. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #532825 Mon Aug 14 2017 4:25pm
You could put your cam belt back on,
Leave your coolant system empty, leave the aux belt off, leave fan off, and start it for a minute. This would give you enthusiasm you have a running engine again.
However, as I said if one of the valve is leaking on the drivers side, you will probably only know after giving it a good drive.
You would then need to remove all the belts at the front, covers, fan, coolant bridge between heads, drain coolant and pull the other head off. Up to you I guess.
Trouble with both these, if you have some loose metal in the drivers side, and run the engine, it could do a lot more damage than currently and you would kick yourself having been so close to fixing the car.
P.S When removing the head, coolant gets into the oil, but this is easily solved by lightly loosening the sump plug and the coolant drains out first.
Ideally you would do an oil change as its a good time to get rid of the black oil which sits on top of the heads.
Post #532843 Mon Aug 14 2017 7:40pm
DerrekL
Cheers Andy. That's some sound advice. I appreciate the knowledge you are passing on and various options I should have when I get this job moving on a bit. Thumbs Up
Is there no way to fully drain the coolant so none gets into the oil or is that inevitable part of this process. RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #532860 Mon Aug 14 2017 8:35pm
inevitable really.
Post #532866 Mon Aug 14 2017 8:53pm
Disco_Mikey
Drain plug in the block will remove all coolant from the heads before removal...
Post #532882 Tue Aug 15 2017 2:47am
DerrekL
OK thanks, I shall have a look at taking the drain plug out. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #532885 Tue Aug 15 2017 7:13am
Ow. Where is that then DM ? Smile
Post #532889 Tue Aug 15 2017 8:29am
DerrekL
OK, I need to go back a step regarding the HPFP cover...
From your memory... how do I get this cover - circled in red in attached picture - out from the bulkhead. What else do I need to take off. It doesn't seem to have any flex in it so I can't get it out the front way from where it sits, does it have to go towards the drivers side bulkhead. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #532901 Tue Aug 15 2017 10:09am
