Home > General > Engine top end strip down |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
Cheers for the links Andy. Buying from these guys is probably the route I will end up taking once I get the head off. Just got this reply back from autoreserveparts regarding the exact head following the link you listed "It includes valves, cams and cam carriers but not the chain." so I'm assuming they mean the cam chain isn't with the head, doesn't that sound a bit dodgy? RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 Last edited by DerrekL on Mon Aug 14 2017 10:22am. Edited 1 time in total |
Mon Aug 14 2017 9:03am |
OK, here's one for you... I read this "The drivers side cam (off side) drives the near side cam, so when the chain breaks the off side is not affected, the near side cam stops, usually with a crunch." here:
Mon Aug 14 2017 9:44am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
When I purchased one from them it didn't come with a chain. Maybe they consider a chain isn't a second hand part you should be using. Naughty of them to show it in the picture. You could always do a deal and ask them to give you a chain for the same price. |
Mon Aug 14 2017 10:41am |
Yes that's what I thought and it also doesn't state in the description that chain isn't attached. Anyways I will persevere with taking the LH head off just now and continue to search for another cylinder head. RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Mon Aug 14 2017 11:07am |
I see chain and tensioners are £110 on eBay so worth trying to do a deal with a head |
Mon Aug 14 2017 11:35am |
Yes I think so to. As I would have thought if you are buying the full head... well... you should get all the bits with it. It's worth watching out for/asking about when I do go to buy one. RRS 2.7 HSE Stornoway Grey
Mon Aug 14 2017 12:49pm |
OK, yip get what you are saying. Hopefully get the LH side completed in due course then can consider RH side. RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Mon Aug 14 2017 4:25pm |
You could put your cam belt back on,
Mon Aug 14 2017 7:40pm |
Cheers Andy. That's some sound advice. I appreciate the knowledge you are passing on and various options I should have when I get this job moving on a bit.
Mon Aug 14 2017 8:35pm |
inevitable really. |
Mon Aug 14 2017 8:53pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Drain plug in the block will remove all coolant from the heads before removal... |
Tue Aug 15 2017 2:47am |
OK thanks, I shall have a look at taking the drain plug out. RRS 2.7 HSE Stornoway Grey
Tue Aug 15 2017 7:13am |
Ow. Where is that then DM ? |
Tue Aug 15 2017 8:29am |
Tue Aug 15 2017 10:09am |
