![]() | Home > General > Engine top end strip down |
Dont forget to check the cam chain etc - if it has broken or become jammed that could be another reason each cam feels different - I have heard that the valves crashing into pistons on one side of the engine and the cam coming to a sudden stop can cause the cam chain or its bits to also fail.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5039 ![]() ![]() ![]() |
You replace the damaged ones.
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
Cheers... so a replacement head could be the way to go.
yeah while its in bits, you need to remove the other head for inspection.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4457 ![]() ![]() ![]() |
Yes, both heads need removed for inspection |
I did break off a valve in my old subaru - the valve head bounced around putting dents and gouges in the top of the piston and head - being tight I just replaced the valve and put the head back on - car ran fine for at least another 200,000km until I sold it. Is not recommended but something to consider ![]() Arctic Frost Aspen Interior |
Thanks for replies....
The rear cam pulley is a |
OK not looking too great for me then. I will try to tackle these jobs you listed one at a time DM. Is there any guides on here for these jobs? |
I've taken the head off in situ.
OK cheers Andy, that will be this weekends to-do list |
slowly getting all the parts off the LH side... however how the |
Hopefully you have the cambelt guide printed out.
abilover Member Since: 03 Oct 2016 Location: East Yorkshire Posts: 29 ![]() ![]() ![]() |
This is compelling stuff, following this one with great interest. Many thanks to DerrekL for the regular updates. Hope for a satisfactory conclusion |
