Home > Maintenance & Modifications > Today's Task - Twin Electrics Install |
FrostyAndJim Member Since: 16 Jan 2016 Location: Gloucestershire Posts: 10 |
Thanks. Yes i can see the loom coming through there. Its all taped up with the reverse sensors as what looks original? So you think take it out start again? |
Fri Jul 14 2017 11:25am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4976 |
well normally when the light is removed, you see the parking sensor plug
Fri Jul 14 2017 4:39pm |
Just the plug for the lamp and a single connected plug and socket for the sensors. A thick bundle of cables coming through a gromit for the sensors and i guess on to those 3 sockets behind the bumper. Im gonna have to get that bumper off and i suspect i'll end up replacing the existing loom. |
Fri Jul 14 2017 5:16pm |
so someone has had a tow bar fited and half removed it by the sounds of it with the 2 grey plugs having cables attached and a set of fuses in the boot if i were you i would strip it all put and start again with your kit i assume you bought a specific kit for the sport |
Fri Jul 14 2017 5:26pm |
Yes i think it is the right kit.ive nothing to attach to the green plug behind the panel. Anyone know what that bit is? It is currently wired to something. |
Fri Jul 14 2017 5:43pm |
Fri Jul 14 2017 5:49pm |
Lets see a picture of what you have got behind the nearside rear panel next |
Fri Jul 14 2017 5:51pm |
Here you go. Im pretty convinced ill just get and replace it all now. A job for the morning.
Fri Jul 14 2017 6:58pm |
so if yours has no sockets at the rear from that photo someone has taken them off as that looks very much like the towing set up so you would be better to start from scratch you should not need to remove the bumper you can feed the cables everywhere without removal and know at least it is all safe |
Fri Jul 14 2017 7:10pm |
Sounds like the best plan thanks. I'll let you know how i get on. |
Fri Jul 14 2017 7:25pm |
So the cabling I took out was original.
Sat Jul 15 2017 4:39pm |
glad you are all sorted |
Sun Jul 16 2017 6:57am |
