Home > Maintenance & Modifications > Today's Task - Twin Electrics Install
normally removing the passenger light would reveal the short? loom and enable fitment, so I would do that as step one. (need to anyway to remove bumper)
Post #530315 Fri Jul 14 2017 11:16am
FrostyAndJim
United Kingdom 2006 Range Rover Sport Supercharged Arctic Frost
Thanks. Yes i can see the loom coming through there. Its all taped up with the reverse sensors as what looks original? So you think take it out start again?
Post #530317 Fri Jul 14 2017 11:25am
well normally when the light is removed, you see the parking sensor plug
and 3? plugs for the towbar
so would like to think they plug in there ??????
Post #530332 Fri Jul 14 2017 4:39pm
FrostyAndJim
Just the plug for the lamp and a single connected plug and socket for the sensors. A thick bundle of cables coming through a gromit for the sensors and i guess on to those 3 sockets behind the bumper. Im gonna have to get that bumper off and i suspect i'll end up replacing the existing loom.
Post #530335 Fri Jul 14 2017 5:16pm
geoffsnook
so someone has had a tow bar fited and half removed it by the sounds of it with the 2 grey plugs having cables attached and a set of fuses in the boot if i were you i would strip it all put and start again with your kit i assume you bought a specific kit for the sport Thumbs Up
Post #530336 Fri Jul 14 2017 5:26pm
FrostyAndJim
Yes i think it is the right kit.ive nothing to attach to the green plug behind the panel. Anyone know what that bit is? It is currently wired to something.
Post #530338 Fri Jul 14 2017 5:43pm
FrostyAndJim
Post #530339 Fri Jul 14 2017 5:49pm
geoffsnook
Lets see a picture of what you have got behind the nearside rear panel next Thumbs Up
Post #530340 Fri Jul 14 2017 5:51pm
FrostyAndJim
Here you go. Im pretty convinced ill just get and replace it all now. A job for the morning.
Post #530343 Fri Jul 14 2017 6:58pm
geoffsnook
so if yours has no sockets at the rear from that photo someone has taken them off as that looks very much like the towing set up so you would be better to start from scratch you should not need to remove the bumper you can feed the cables everywhere without removal and know at least it is all safe Thumbs Up
Post #530344 Fri Jul 14 2017 7:10pm
FrostyAndJim
Sounds like the best plan thanks. I'll let you know how i get on.
Post #530346 Fri Jul 14 2017 7:25pm
FrostyAndJim
So the cabling I took out was original.
Once untangled and cut away I was left with the green socket that feeds the light block and the rear parking sensors.
Taking out the old cabling and the freeing up the threads in the nuts to attach the sockets(bit rusty) was what took the most time. But ultimately all done and avoided removing the bumper.
Many thanks for the support, without it I suspect I'd still be pondering what to do about it.
Cheers! Smile Thumbs Up
Post #530420 Sat Jul 15 2017 4:39pm
geoffsnook
Thumbs Up glad you are all sorted
Post #530444 Sun Jul 16 2017 6:57am
