Home > Maintenance & Modifications > Today's Task - Twin Electrics Install
Pufftmw
Today's task was fitting the double electrics into my RRS.
Firstly, had ordered single (7pin) electrics from dan@duckworths but they arrived as single (13pin). Dan very decently sent out twin 7s on a swap out for the same price, so fair play and thanks to him Thumbs Up
I have an HSE with PDC so there please bear in mind if you don't (ie less connectors)
The kit comes with a paper manual, which is pretty clear but not perfect. First thing to note is that it says you will need a 6mm allen key, a phillips and a cutting tool but you will also need a pair of pliers for the earth. I would also recommend a long philips in order to not interfere with the bumper when installing the sockets. It is solely diagrams and you are left to interpret what is what. So I thought I would take some pics to try & match the instructions.
Kit + tools
Remove NS tail light (two philips on the right and ease out)
Insert plate into left hole & use 4 20mm bolts as provided (why is it like this & not same on both sides?)
Insert plug into right side with 3 of the 40mm bolts. Easing the wires through is a bit fiddly.
White plug on the left...
6mm Allen key to undo the tie-down bolts
Once out, you can pull (gently) the panel out
Don't forget to pull out the wire from the 12V socket
Behind the panel, the 3 sockets you are interested in
The 2 grey ones have blank ends, which need to be discarded
Remove the green socket, then pull it through from the outside. This wire can also be discarded.
The instructions say to push the new cable through from the outside but its easier to pull from the inside! Clip plugs to metal chasis.
Re-seat the seal, which is simple. You then have 5 connectors on the outside. Shortest is for the PDC, 2nd shortest for the lights, the rest for the towbar electrics. There is another blanking plug to remove for the PDC
Drop the remaining wire/connectors down the hole behind the bumper
White earth leads to chasis. This is where you will need the pliers or the correct socket tool. There was also no way it would match the schematic for placement, so don't worry if it can't, it will still work.
Run the fuses into the area under the floor but easiest to remove the tailgate floor panel first.
Where holder should go...
In place
Once the above is done, then it is a matter of running the wires along the bumper bar, connecting up the matching wires and hiding up behind the bumper, away from the exhaust of course! Because it was cold and the ground was wet, didn't take any pictures but self-evident as there is not a lot of options.
Finished product & lights working
Hope that helps anyone doing this install
Smile
Post #371069 Sat Jan 26 2013 11:28pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Great write up! I shall add to the 'how to' thread Thumbs Up Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #371071 Sun Jan 27 2013 1:26am
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
Looking good. Will have to add this to my RRS. 91 BMW 850CSI
Post #371072 Sun Jan 27 2013 1:41am
RRS_PAT
Hi,
I've just followed these and I found them very helpful.
Many thanks,
Pat 2011 Autobiography Santorini Black
Post #371237 Mon Jan 28 2013 6:10pm
Pufftmw
RRS_PAT wrote:
Hi,
Many thanks,
Pat
Post #371240 Mon Jan 28 2013 7:07pm
Nice one Puff Thumbs Up Great step by step guide, Wink
Post #371246 Mon Jan 28 2013 7:35pm
grass cutter
Many thanks, will be doing mine soon.
Did you lose any tools down the grid ?
Post #371813 Fri Feb 01 2013 1:06am
Mcfeat
United Kingdom 2005 Range Rover Sport TDV6 SE Zambezi Silver
Just done it myself yesterday took about an hour. Thumbs Up
Post #372233 Mon Feb 04 2013 9:02pm
Cat2975
Did you need to disconnect the battery?
Post #462400 Tue May 19 2015 10:30pm
Bodsy
Site Sponsor
You don't need to disconnect the battery, but on your 3.0 you will need to have them enabled for them to work. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #462403 Tue May 19 2015 10:45pm
Mr Crabtree
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
good thread Working with Virgin Trains and band of Brothers/Sisters to do something special for our injured servicemen and women
Post #485518 Sat Jan 23 2016 9:22am
panda
2007 Range Rover Sport TDV6 HSE Zermatt Silver
Shocked No hammer Shocked
Supporting the London Air Ambulance with my Brothers
Post #485519 Sat Jan 23 2016 9:33am
SRE
Spain
I wonder if they do them in Pink for BC Whistle In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #485525 Sat Jan 23 2016 10:11am
Pufftmw
Apologies to all - didn't realise pics were missing (again) - fixed!
Post #521828 Fri Mar 24 2017 3:02pm
FrostyAndJim
United Kingdom 2006 Range Rover Sport Supercharged Arctic Frost
So I bought a loom to do this some time ago and only recently got to having a go. The loom I bought has an inline cable for each of the lights and two grey plugs to go behind the left panel (no green plug on the loom). The actual tow sockets are not wired so the loom has two sets of coloured cables to plumb in. When I went to fit it I found I seem to have electrics. At least partially. The grey plugs behind the panel are connected to cables running off. There is a set of six fuses in the boot. After some crawling around I've spotted three sockets up behind the bumper. Not very accessible without bumper removal. So... Should I get and tear it all out and fit the loom I bought or is there a kit that will plug into the three sockets behind the bumper? Not sure how long those sockets have been open to the elements. Might be ok?
It's a 2006 4.2 V8 supercharged petrol.
Post #530310 Fri Jul 14 2017 10:37am
