![]() | Home > In Car Electronics > In Car Head unit replacement issues |
hoppy89 Member Since: 26 Apr 2016 Location: birmingham Posts: 36 ![]() ![]() ![]() |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Can you take a picture a bit closer please?
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
![]() Many thanks, looks good & just the right trim/colour as mine too. Think I'll be getting one now. Thanks again PS - Ignore the haters... |
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 ![]() |
Had the same issue with mine and it's an easy fix, take your battery wire off and on at midnight and the clock is set spiteful Range Rover Sport tdv8 |
cheers olly, I can reset it with the iid tool, but by midnight I'm usually as snug as a bug in a rug...zzzzzz
You need to split your old radio in half and stick it in the dash to keep the top screen working, it's not a hard job. Well worth it as the top screen has all the 4x4 and suspension info spiteful Range Rover Sport tdv8 |
So, got all the bits now, job for next week when I'm in Ireland and its bound to be raining... Luckily I have a garage there |
New HU is part fitted - its working OK, just need to do some more bits:
How do you get to the wires at the amp ?
Its only the green plug that needs to come out for the bypass and I guess it would be possible to do it without loosening the amp but I chose to unbolt (8mm socket) the 2 retaining bolts either side, which allowed the amp to rise about 15mm, which in turn was enough room to get the plug out. |
Small update...
For reversing light feed, I would run the wire down from the roof to the passenger side, and connect to the towbar plugs in the left side of the boot.
Hi Andy
Sorry I can't really help as I'm not familiar with the headunit.
