![]() | Home > In Car Electronics > In Car Head unit replacement issues |
hoppy89 Member Since: 26 Apr 2016 Location: birmingham Posts: 36 ![]() ![]() ![]() |
https://incartec.co.uk/Pages/Product.aspx?P=4873
Range Rover Sport fitting with screen retention FK-853-3 |
fitted today, yes that kit works |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Do you use the bluetooth on the new head unit or is it still using the old bluetooth TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
the new one |
Great thanks, just wanted to check |
my pioneer unit came with a free dab antenna, fitted to passenger side front screen... took the mrs 5 days to know it was there |
Perfect cheers. Thats the head unit i am considering actually.
does everything I want it to do,(its head & shoulders above the oem unit) new mic is fitted behind mirror,
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
Do you have access to the RRS setup menu in the command display to setup things like headlamp delay, change from miles to km etc etc etc.
i do indeed |
Thanks - I was led to believe that this function needed the original radio (like the dash clock) but clearly not.
