![]() | Home > General > ctek mxs5.0 |
Yes but, you need to connect the Live/Red Lead to the Battery and the Earth/Black lead to one of the Earth Studs due to the Battery Monitoring System, there are Several Studs on the inner wing valance close to the battery.
The 2011 set up is different to the RRS 2 and does not have the separate Jump Start/ Booster terminal/connectors under the bonnet.
JanRRS Member Since: 29 Dec 2015 Location: in my car ... Posts: 41 ![]() ![]() ![]() |
Cheers Col.
this video might be very useful:
I asked my good lady to get me the CTEK MXS 5.0 as a present, (do some 2 mile runs a couple of times a day) she duly ordered it, but it was out of stock, so unknown to me, she purchased what I believe may be the next model up, the MXS 7.0. Could anyone confirm this is still OK to charge after short runs etc, and that connections to car/battery are the same as the 5.0 you have all been discussing? Also what's the difference between the two? Thank you. |
Actually the 7.0 is a better option not that you need it but it can act as a power source as well, it connect in exactly the some way as a 5.0.
fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180 ![]() ![]() ![]() |
Thanks for that Col. |
Thanks from me to Col, saves a lot of research and checking. |
No problem Guy's, if you have a look through my gallery If I remember right I think there are a couple of photos of the terminals I used to connect mine.
I will check that out, great thanks. |
As far as I have been told by the dealer, the 5.0 is ideal for the RRS. The 7.0 (to 225 Ah) and the 10.0 (to 300 Ah) are for bigger batteries, i.e. caravans, etc ... And more for professional use. And obviously do cost more. I would just stick to the 5.0, which does the job perfectly. I have been using it for both my BMW X6 and my Porsche 4S. And use it also for my HD bike. |
5, 7, 10 and even 25 are all suitable for RRS. It's just that higher current means quicker charging. Plus as Col said 7 and upwards offer the power supply mode which can be very useful when a stable, uninterrupted 12v supply is needed for example when editing and uploading the CCF file to configure the car.
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
Just as a final point regarding length of charge, my neighbour owns a Shogun. He works in the marine industry and does 4 months on / 4 months off rotations. When he goes away he puts his car on a maintenance charge with a CTEK 7.0 for the full 4 months he is away and has never had a problem!
