Home > General > ctek mxs5.0 |
Do you have the rear tow eye electrical sockets on your Sport - I purchased the connector from the forum. It has a connector that fits to the CTek & then it plugs in the back of your Sport - great piece of kit
Thu Jan 21 2016 6:51pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Towing socket is obviously the best solution but if like me you don't have towing electrics, it is OK to charge via the cigarette lighter socket. Bear in mind the sockets are not permanently live. If you connect a charger to it, it will start charging fine but will stop as soon as the car goes to sleep (2 minutes after locking?).
Thu Jan 21 2016 7:13pm |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
right thanks for the info guys guess i will have to just use the normal comfort lead to charge don't really want to start taking relays out but thank you for the info |
Thu Jan 21 2016 7:26pm |
Do you have the towing sockets ? 16MY Estoril Blue SVR.............
Thu Jan 21 2016 7:30pm |
no i don't have towing sockets , well i don't think i do ? |
Thu Jan 21 2016 7:35pm |
Have you ever removed your rear towing eye cover ? use a coin on the 2 plastic screws - remove them & then remove the cover - behind is the connections - its a 2 minute job - if they are there you will have the best route to use the CTek IMO 16MY Estoril Blue SVR.............
Thu Jan 21 2016 8:17pm |
i will definatly check tomorrow I've never bothered looking , thank you for all the advice guys |
Thu Jan 21 2016 8:20pm |
If I don't have to tow bar electrics how have you guys set up the comfort lead? |
Fri Jan 22 2016 9:30am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Hardwire to Battery
Fri Jan 22 2016 9:54am |
I thought the negative lead needed to be earthed to the body not the battery ? |
Fri Jan 22 2016 10:09am |
I think that may only be relevant on Facelift Models with the Battery Monitoring System, on my Pre Facelift that's how I wired it and never had a Issue and I left mine for 3 months at a time when working in the Middle East.
Fri Jan 22 2016 10:23am |
Brilliant thanks for that makes things a lot easier to connect up for me |
Fri Jan 22 2016 11:47am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
I think this thread must have jinxed me today,,,, considering mine is garaged each night and is never really subject to temperature below 10 deg. Jumped in early doors to move it onto the drive,,, turned over as normal,,albeit for a little longer than usual and the battery promptly died!. Connected the cheapo charger I have and left it on for a couple of hours, charger off and also added my portable booster and managed to get it going.
Fri Jan 22 2016 12:01pm |
Ive been meaning to buy this charger for ages but after these cold mornings thought i best get it. Just trying to find the best way of fitting the comfort lead now |
Fri Jan 22 2016 12:25pm |
