Johnski
The reason I wanted/needed one, (I have the 7.0) is because even though I have a good battery,
For some reason with the short runs and trips abroad for up to 20 days, I arrive back at airport to a flat battery.
I didn't realise the drain caused by alarm monitoring, tracker etc would run it down. I have had LR check the battery, and they have confirmed it is fine, and said due to type of use, it either needs a permanent trickle charge or a full charge every 4-5 days. They did say they could fit LR version of this.
Not sure if this is correct, and didn't expect security systems to run battery down, but anyway that's why I have mine.
Anyone else had problems with airport parking drain and short runs? I also of course do long runs as well (this last year 16000 miles). John
Mon Jun 27 2016 1:16pm |
