![]() | Home > Maintenance & Modifications > winter is here, drl's to be installed |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
excellent idea, thank you. I have my lights open still and I'll be getting this done during the week. top marks. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
TrevG Member Since: 14 Aug 2012 Location: Kent Posts: 48 ![]() ![]() ![]() |
I got my originals from sparky on the forum but been having trouble with my near side headlight recently when it does the self levelling jig on start up it doesn't always come back up and stays facing down so got some more lights and Sparky hasn't got anymore so I've got the Dabhees version but might try removing the diffusers over the led's for a cleaner look.
Hi all,
On all the time and reduced brightness by about 40% with headlights on.... |
that's gonna be difficult TrevG without some sort of resistor. My DRL's dim when the headlights are on so it would make sense. I'll wire them to the ignition live and then do some testing to see if they are too bright at night when the headlights are on. If they are, I'll have to make the change you suggest. Cheers. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 ![]() ![]() ![]() |
This thread along with watching some videos of disassembling headlights has given me the confidence to try this.
Just a little update. The rings arrived and they turned out to be useless. Two of the led's on one ring stopped working after an hour. Simply wasn't confident in the other three after that. British quality at its finest. No wonder I outsource a load of my work further East. Anyway, I ordered then the dabhees rings and they are excellent quality. I took the reflectors off and wrapped them in carbon fibre film. End result:
another one:
....got mine from Dabhees. Haven't tested them yet but they look good.
it's a job and a half, can't wait to get it finished. I'm painting the internals carbon black just to make it more difficult for myself |
....Plastikote primer and top coat?
the lens was a pain in the rear end. heat gun and lots of patience. putting it back on is simple though |
I'm collecting all sorts.
brilliant. i've connected the white and red wires from the rings to the live wire on the dimming module.
