Home > Maintenance & Modifications > winter is here, drl's to be installed
Page 4 of 7 <1234567>
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
That's strange, mine have been piggy back connected to the fuel pump fuse now for over 12 months without any issues.
It's only a feed so if everything is connected correctly I don't see why it should cause a problem, but then again who knows with these cars.
Post #441572 Wed Nov 05 2014 1:11pm
TrevG
I used the ignition live as flydrive see thread.. Thumbs Up
http://www.rrsport.co.uk/forum/topic31182.html?highlight=fuse
Post #441574 Wed Nov 05 2014 1:33pm
tanloverluke
agreed, very strange! I asked the LR teccie and he said no way would that cause a problem. But the garage saw that with the drl's on the pump stopped working. Maybe it's a sign that the pump is on its way out, we'll see.
What I've done anyway, thanks to the post http://www.rrsport.co.uk/forum/post385109.html#385109, is to slot the yellow wire directly into the spare relay 12 ignition live slot. I've confirmed with the multimeter that it's live only with ignition on. And there's about a 15 second delay between taking the key out of the ignition and the drl's switching off.
Here is my fuse box now. I'll be buying a more rigid spade connector at weekend:
 Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #441576 Wed Nov 05 2014 1:50pm
tanloverluke
TrevG, you replied whilst I was writing my previous post. All credit to you my friend!!! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #441577 Wed Nov 05 2014 1:50pm
Paulcp
I did look at the spare relay option from the same thread, but on my Black Edn there is no live in the spare relay slots
Looks as though the wiring is different on different model year cars
Post #441579 Wed Nov 05 2014 2:50pm
tanloverluke
Paul, do you have the dormant wiring loom by the front radiator? Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #441610 Wed Nov 05 2014 7:04pm
Paulcp
TBH I can't remember, will check tomorrow
I did read though (cant remember where) that the live on that connector does not stay live all of the time and works in the same way that connecting direct to battery with a fused link does. This means that the DRLs will go off at idle and sometimes on engine overrun once the battery is up to charging capacity. I originally took the easiest option of the fused link to the battery and had this problem.
There's a lot of info on the US RR site about this
I was originally apprehensive about piggy backing on the fuel pump fuse but I've had no problems in 15 months
Post #441618 Wed Nov 05 2014 7:53pm
simbad111
wiring info for drl
Hi guys could anyone help with a little info regarding wiring of drl rings that I have purchased, the rings have black red and white cable attached, I have also purchased a auto drl switch which also has red black cables which connect to the rings the switch also has a white cable, my question is where do I connect both white wires to, may be simple answer but rather be safe that sorry,
Post #444964 Wed Dec 10 2014 7:42pm
TrevG
This may help..
For two level Brightness rings,
Red and White wires = Positive, Black wire = Negative
One level brightness: Red colour positive wire + Black negative wire.
Two level brightness: Red colour positive wire + Black negative wire + White colour positive wire.
Post #444970 Wed Dec 10 2014 9:13pm
tanloverluke
Re: wiring info for drl
Yep, red to the live of the battery, black to the chassis, and white to either the live of the headlights or the fuse box. If you have only 3 wires I would have though the 3rd white cable goes to the fuse box, otherwise your lights would be on permanently.
any instructions with them? Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #444996 Thu Dec 11 2014 9:52am
simbad111
drl plunge taken
After many question and many post read I finally took the plunge and decided to install led drl rings on my RRS, the only scary part was putting lights into the oven but little and often rather than long period in the oven seems to work for me, I searched for ages to find the correct rings for me 5 led rings, each to there own though, I painted the internals satin black and changed the amber side refactors to clear ones, I am really pleased with the outcome,
Post #445282 Sun Dec 14 2014 12:31pm
mad-dafty
Scotland 2010 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
Nice job mate, love the clear reflector. Thumbs Up 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
2006 RRS TDV6 2.7 HSE -Java Black
2008 BMW 3 Series 2.l
2006 BMW 5 series 2.l
Post #445288 Sun Dec 14 2014 2:40pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Re: drl plunge taken
Can you take a front only shot off this too? looks ace.
Post #450785 Sun Feb 01 2015 6:16pm
tanloverluke
the reflector looks ace! how did you make it? I was looking high and low for a sheet of refective plastic.
Thx
EDIT:
Now found: http://www.ebay.co.uk/itm/Lumite-Prismatic...58b3c39a1f Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #450875 Mon Feb 02 2015 11:12am
TrevG
I made mine from a fluorescent light diffuser, about £7 from Wickes. Thumbs Up
Post #450882 Mon Feb 02 2015 12:33pm
