![]() | Home > Technical > Big Fuelling Issue |
cobbler2u Member Since: 09 May 2010 Location: hertfordshire Posts: 69 ![]() ![]() ![]() |
Exactly.
Men and Complex machines...nothings perfect, everything breaks - never expect it to be flawless or perfect, otherwise expect it to fail. Mike
All things should be fit for purpose, this is reinforced by consumer legislation.
Any bush is definitely a wear and tear service item, I would say the lower arms are.
^^^ Seller's allowed at least 3 attempts to cure a fault -I think given sufficient grounds you can expect a replacement for up to a year. After that it becomes a debate with dealer, who is only backed by JLR.
Agreed nothing takes away your rights, I think your rights are different in the UK, you cant take your car in after 6yrs and get a new one here Mike
Have the same problem.
^^^ Not so DrDill
No need to insult or be high-handed – let’s not bother to trade CVs so unless your 32 years retailing is in the Motor Trade forget it.
Absolutely last post on this as it is clear that you are not willing to read the context of the thread and what's actually written but would much prefer to argue.
jdgeary1 Member Since: 11 Dec 2012 Location: Berkshire Posts: 41 ![]() ![]() |
Well, after everything thing my car has been through, I have finally reached the end and its been resolved.
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 ![]() ![]() ![]() |
I'm very pleased you have got it sorted, now try and get some faith back and enjoy it. |
Great news. Thanks for posting the solution. It is so much more useful to have a post about a problem that includes the way it was finally fixed. |
