![]() | Home > Technical > Big Fuelling Issue |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Hope they find out soon - must be costing you a fortune |
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
I think. like many professions, no-one wants to give advice in fear on being on the end of litigation when its the wrong decision.
jdgeary1 Member Since: 11 Dec 2012 Location: Berkshire Posts: 41 ![]() ![]() |
Well saga continues, Range Rover/Land Rover cannot diagnose the fault, they are stumped!!!!
Vehicle is unfit for purpose so I would be looking for refund or replacement |
That's what Ive told the garage I purchased it from, but its madness that Land Rover cannot rectify the fault and cant even diagnose it.
Sadly you are now part of a growing group on here |
H16UUP Member Since: 23 Aug 2010 Location: Stockport Posts: 31 ![]() ![]() ![]() |
Did they replace the fuel pressure sensor in the end? Also, it would help if you could get the fault codes from the technicians & let us know them. Have they ruled out the EGR valves or is it definitely low fuel pressure? 2006 TDV6 SE, Zermatt Silver |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Drop test -CHECK scratch test -CHECK interior colour - N/A Interior swap -CHECK NEW CAR - TBA |
The fault code related to something called Fuel Deviation. It seems to happen intermittently and also under load, as it seems ok on a ramp running the car.
Checked, Fuel Pressure Sensor has been replaced also, checking on the actual fault code but am sure he said it was fuel deviation. They have checked the fuel pressures as there is a drop off 5 bar to 2 bar or something similar, not 100% sure, but it should be higher and it drops low.
Oh and the car is at Rover Tune in Reading, Rob is pulling his hair out if anyone can HELP..........
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Inter cooler hose Collapsing and starving the car of air no air=no need for fuel seen it before on scoobys and Evo's |
P229000 - Injector Control Pressure Too Low Probable Causes: • Fuel pressure control valve (FPCV) maximum limit reached • Fuel injector control pressure too low • Fuel line leak • Fuel filter/system restriction • FPCV circuit fault • FPCV failure • Fuel pump module circuit short circuit to ground • Fuel pump module failure • Fuel injection pump failure What to do: Check the fuel pressure. Check the fuel lines for leaks/damage. Check for a blocked/restricted fuel filter. Check the fuel pump module circuits. Check the FPCV circuits. Check the fuel injection pump. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Coxylad Member Since: 11 Jul 2013 Location: Preston Posts: 48 ![]() ![]() ![]() |
If you take your car to a garage to be fixed and they change a part that didn't need changing because they got it wrong why should you have to pay for it??
