![]() | Home > Technical > Big Fuelling Issue |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 ![]() |
Have they changed the fuel filter there's been a few dodgy ones about..
JPR 1 Member Since: 29 Jan 2013 Location: Cheshire Posts: 435 ![]() ![]() ![]() |
Mine did exactly the same a couple of months ago, ended up being the fuel filter, it still took them nearly a week though to find it. I would say this is definatley what is wrong with yours.
jdgeary1 Member Since: 11 Dec 2012 Location: Berkshire Posts: 41 ![]() ![]() |
Yep fuel filter changed twice so far |
Had the wiring out and checked it all as well
Have they checked the turbo actuator linkage to make sure that is free and not seizing up..
SpikePCR Member Since: 15 Apr 2013 Location: Benoni Posts: 14 ![]() ![]() ![]() |
Check the pressure sensor on the fuel rail mine did the same turned out to be a faulty sensor |
Ahhh thanks will suggest those two as well and have them checked |
alanp69 Member Since: 27 Jun 2013 Location: Tipperary Posts: 4 ![]() ![]() |
Hi .... I'd be very interested in the outcome of this as my 07 TDV6 is doing much the same (see recent post in Technical issues titled Faults at Speed) so far they've done injectors and filter but still not sorted, my biggest worry is that when the injectors were done they didn't do the filter so they could be dirty again !
Sounds like a very similar issue, I have had both fuel pumps replaced so far, fuel filter, injectors checked and they are fine, ecu checked, electricals checked and still no fault found.
I feel your pain ££££££££ , Mine has been in 3 times with this now and were none the wiser ! ... Add to that for the NCT (MOT in Ireland) I had to buy 2 tyres , then it failed on a suspension imbalance so I had to buy 2 rear suspension units which set me back €1000 fitted and now this fuel fault .... If that's what it is ? Like yourself my patience and wallet are getting thin ! |
Ok a further update if anyone has any clues, it seems after further tests and diags by a top range rover electronics guru, the fuel issue seems to be happening only when the car is under load.
Have they checked the vent is clear for the fuel tank so it can breath and not cause a vacuum while your under load.
Ah, could be, will see if that has been checked also and let you know the results. |
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 ![]() ![]() |
easy:
