Home > In Car Electronics > Adding Freeview/Rear View Cam Required |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
i take it that the digital tv tuner is way better than the standard pile of poop tv tuner, Peachy? Do you get all freeview channels with it, and some more ?
Sun Oct 20 2013 7:18pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
I haven't really had a good play yet - seems a decent bit of kit - I will add a few videos on this thread over the next few days - it picks up the digital radio but still early days - they had an Alpine tuner which was £500 reduced to £224 but the aerials pushed it back over £300 without installation - I rarely spend more than an hour in the RRS at any one time so more of a toy than a practical piece of kit - I can always upgrade if its something I find worthwhile. 16MY Estoril Blue SVR.............
Sun Oct 20 2013 7:30pm |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 |
You must be running out of things to do by now Mr P? |
Sun Oct 20 2013 7:44pm |
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 |
Thanks for the discount code
Sun Oct 20 2013 8:13pm |
Sparky - Your right but very time I think that - something else comes along : H - your welcome to look at my set up if needed - 16MY Estoril Blue SVR............. 17MY Autobiography Dynamic - Corris Grey - WOW. 14MY Autobiography Dynamic - SDV6 - Fuji White 12MY Autobiography - SDV6 - Santorini Black - Dual View - Rear Entertainment - Sunroof. 12MY Autobiography - SDV6 - Orkney Grey - awesome ;( 2005 Java Black - 4.2 V8 Supercharged First Edition- will never be forgotten ;( |
Sun Oct 20 2013 8:19pm |
Cheers P
Sun Oct 20 2013 8:23pm |
This is what i think i know The tuner needs an interface to make the picture - this is the GVIF unit - the tuner is connected to the GVIF with the normal red - white & yellow aux connectors then is hard wired for the power & antennas installed as discreetly as possible on the top corners of the windscreen. The tuner is TV in motion
Sun Oct 20 2013 8:33pm |
A friend of mine previously had the antennas fitted to the back quarters and the picture was very clear on the tuner he purchased but no longer has the car to advise about the tv in motion.
Sun Oct 20 2013 8:44pm |
Came home after fitting on the M42 - nothing overtook me no probs with pic or sound quality - but the fitter advised - tints cause interference & restricted signal - I'm gonna do a bit more research on that tomoz 16MY Estoril Blue SVR.............
Sun Oct 20 2013 8:50pm |
Ok brill the interface may support it then.
Sun Oct 20 2013 8:55pm |
Macahooch Member Since: 17 Aug 2013 Location: Manchester Posts: 5 |
Gents,
Thu Oct 24 2013 10:21am |
rabbutler Member Since: 11 Dec 2009 Location: Aberdeen Posts: 187 |
You could go into Diagnostics mode and video input test, this will enable you to have the TV on while the car is moving.
Sat Oct 26 2013 7:09am |
Hi Rab,
Sun Oct 27 2013 1:44am |
Tony, the 2010 rrs and D4 gvif is a lot more involved to install. You have to take the touchscreen out and remove the sceptres from the rest of the unit. Then put a small pcb in connected with flexible ribbon. I've installed a couple of these, but they're not for the faint hearted.....
Sun Oct 27 2013 8:14am |
