![]() | Home > In Car Electronics > Adding Freeview/Rear View Cam Required |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
is it only when it's on satnav screen Peachy, what about when you're in the main screen ? i'm hardly ever in satnav screen and dont want to have to switch to it just to have to get the reverse camera working. call me lazy !
The gvif unit plugs into the satnav DVD player and interrupts the signal to the screen, therefore, it needs to be on the satnav screen. The warning message screen is ok, it doesn't need to have the map on specifically. |
bodsy, why then is awd man getting the reverse camera coming on regardless of what screen he's on ? it's due either to 1) it being wired incorrectly, or 2) he's dillusional |
Errrrr without offending, I'd have to pick number 2... |
just pm'd him...let's get this put to bed once and for all.
TLL - Harry has the same set up as me - helped by Bodsy I believe |
Peachy, i live in dorset which is one big muddy field ! the problem i suppose is when im faced with a restriction, in this case having to be on satnav screen, my brain goes all funny and negative. i want things to be easy and smooth (just like my hoes |
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 ![]() ![]() ![]() |
TLL sorry about the late reply been away for a while.
Thanks for that Harry.
TLL the topic details everything that was installed.
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Not if you are on info 4x4 screen '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
